Old 08-09-2010, 02:08 PM   #1
frenchy dehoux
frenchy dehoux's Avatar
Default Ford Flat Head V8 engine block brace
I am looking if someone knows of anyone making or selling for a V8 Ford Flathed the the main brace that is bolted on the exhaust side of the block to hold the engine on the stand. I have one for the V12 engines but I can not use this one for the V8 as the exhaust port are further away. Please let me know.
Thanks !
Frenchy
frenchy dehoux is offline   Reply With Quote
Old 08-09-2010, 04:28 PM   #2
36tbird
Default Re: Ford Flat Head V8 engine block brace
did you look on the 'bay?
36tbird is offline   Reply With Quote
Old 08-09-2010, 05:10 PM   #3
Elmo Rodge
Elmo Rodge's Avatar
Call Jim at Antique Ford in Rosemead, California. 626 288 2121 Let it ring. Sometimes it takes him a while to answer. Wayno
Life is not a spectator sport.
Elmo Rodge is offline   Reply With Quote
Old 08-09-2010, 05:26 PM   #4
JM 35 Sedan
JM 35 Sedan's Avatar
Check with this guy http://www.stumpysfabworks.zoomshare.com/
Good well made pruducts at good prices. JM
John
Old 08-09-2010, 05:56 PM   #5
frenchy dehoux
Thanks for the heads up.
Frenchy
Old 08-10-2010, 12:15 AM   #6
coilover
I made one that holds the engine in the north-south direction instead of cross wise like the exhaust mount one. Made the spacers between the mount plate and bell housing holes long enough to allow flywheel/clutch work but most important is the additional brace from the top of the mount plate to the rear four intake bolt holes. My stand is a four wheel heavy duty one so I don't know if a Harbor Freight one could take it but my head plate is welded to a 3/4 ton spindle and turns in bearings so it's not a problem.
coilover is offline   Reply With Quote
