Old 02-04-2013, 05:27 PM   #21
1932 V8
1932 V8's Avatar
Default Re: Schramm air compressor
Here's mine . She's a beauty ! Ha !
1932 V8 is offline   Reply With Quote
Old 02-04-2013, 05:31 PM   #22
1937pickup
Can these engines be converted to car use again?
1937pickup is offline   Reply With Quote
Old 02-04-2013, 06:46 PM   #23
Al K.
Al K.'s Avatar
Yes, the plugs in the valve pockets need to come out and be replaced with valves. The intake and carbs also need to be replaced too. Mine ran and made air before I put the block in my P/U and mated it to my T-5. Al K.
Al K. is offline   Reply With Quote
Old 02-04-2013, 07:08 PM   #24
KiWinUS
KiWinUS's Avatar
WOW that thing is awesome !!!!its like 36 ford heads , keep us all up to date when you start to make her a runner !
Thanks for the pics
Old 02-04-2013, 07:12 PM   #25
KiWinUS
KiWinUS's Avatar
THANK YOU THANK YOU THANK YOU !!!!!!
To all that have replied to this post . Thanks for all the help you have all been !!!
I am going to take everyone up on their offers & keep you all up to speed with my progress on my Schramm . the more I have checked it out in my trailer the nicer it seems to be .
again Thank You ALL !!!
Cheers
Tony
Old 02-04-2013, 07:13 PM   #26
VeryTangled
VeryTangled's Avatar
Learning now! Hitting on four and pumping on four.
Great shot of the starter to oil pan area. We had more than one discussion about putting a brace between the starter bolt and the pan.
-VT/Jeff
Old 02-04-2013, 10:30 PM   #27
Jim A
G.M.
THANKS! I will send you an email tomorrow, been sitting in a plow truck for about 14 hours, time for some sleep before back on the road at 4am.
Tony, good talking to you, will be in contact tomorrow evening, unless the snow keeps falling.
I will post a picture of my Schramm Fordair when I get a minute, until then, have a great night all.
Jim
Jim A is offline   Reply With Quote
Old 02-04-2013, 10:47 PM   #28
skidmarks
skidmarks's Avatar
spent some time around a schramm drill rig welding casings. we also had a few compressors but they were the later 4, 6 and twin 4 type that was all schramm. they loved to drink gas. the schramm tractors were neat too. everything about them was heavy duty.
i had a V8 ford water pump that was also built in west chester, did schramm ever build them or just air compressors ?
skidmarks is offline   Reply With Quote
Old 02-05-2013, 07:53 AM   #29
awelker
awelker's Avatar
I have two of the Schramm Fordair's and even with the manual I wanted to understand the slowdown and unloader valves better before starting. So a simple test which I learned alot and I feel is a good check is with to hook up an airline from another compressor with a regulator valve with the Schramm not running. Then slowly turn the regulator pressure up and down and you can test all the unloader and slowdown valves easily. Also will see if the pressure relief works properly.
Also a good idea to remove the intake and pressurize the unloader valves so you can see if they are working properly.
Andy
www.vonwelker.com
https://www.flickr.com/photos/vonwelker/albums
Home of the Blonde Bitch Bellytank
awelker is offline   Reply With Quote
Old 02-05-2013, 07:28 PM   #30
KiWinUS
KiWinUS's Avatar
Originally Posted by Gary in La. View Post
Send me the serial number when you get it out of the trailer and I can maybe give you the date it was built. I have a pretty complete factory S/N list.
Gary , I went in trailer & removed the data tag
serial #98680 but the 6 was a 5 & had 6 stamped over it .
thanks for all the help.
Cheers
tony
Old 02-05-2013, 09:04 PM   #31
Gary in La.
Gary in La.'s Avatar
With those numbers,either way, shows it built in 1946 as a FORDAIR.
Gary in La. is offline   Reply With Quote
Old 02-08-2013, 06:23 PM   #32
bryna
This is my model 60 Fordair... both Jim A. and Sam Hardgrove were of great help getting mine done. It makes air like crazy...
bryna is offline   Reply With Quote
Old 02-08-2013, 11:24 PM   #33
G.M.
Skidmarks, I don't know if Schramm ever made water pumps. There was a company named National Foam that was in Westchester but move to Exton,Pa in the early 50's. They made fire engines and may have made pumps. Also Hale fire pump was in the area. G.M.
www.fordcollector.com
Old 02-09-2013, 12:41 AM   #34
Dick Webber
Not to hijack the thread, but it brought to mind this picture I took at Zolfo Springs FL years ago. I first thought this was a 337, but not so. Living in the backyard of Gordon Smith Co. air compressors converted from Fords interest me. I don't know if this is a Shramm or a Smith or ?? Maybe it will help identify the carbeuretor.
Dick Webber is offline   Reply With Quote
Old 02-09-2013, 01:00 AM   #35
Jim A
Dick, that's a Schramm fordair compressor.
Not sure about water pumps- will have to see what I can find on that.
Old 02-09-2013, 09:14 AM   #36
G.M.
That's a Schramm, pre 39. I have a Smith compressor also with a modle A engine. I never fooled with it. I may sell it if anyone is interested. G.M.
Old 02-10-2013, 07:36 PM   #37
Jim A
Attached are some pictures of the Schramm Fordair 60 Crawler. By Schramm records they produced 150 crawlers, this one it number 23 or 24 made ( I forget which, will have to look that up again). This was produce with full rubber tracks, which they had a lot of problems with throwing a track when you turned, Schramm recalled the early ones and fit with steel track, which is what the later ones came with. For some reason this one was never refitted with steel tracks.
Old 02-10-2013, 07:44 PM   #38
1952henry
1952henry's Avatar
That is neat!
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 02-10-2013, 08:09 PM   #39
KiWinUS
KiWinUS's Avatar
WOW that baby is awesome !!!!
Thanks for sharing Jim , & thanks for all the help you have been !
Cheers
Tony
Old 02-10-2013, 08:24 PM   #40
Jim A
Thanks guy, Was about a 5 year project. Took about 2.5 years dealing on making tracks for it.
Tony,
Attached are some scans on the Fordair 60, I have about 25 pages scanned. If you want to send me your email I will send to you.
Jim
