Old 01-11-2013, 01:53 PM   #1
miss victoria
Default F150 trans pictures
Here are pictures of my ford f150 o.d trans to fit an early v8
miss victoria is offline   Reply With Quote
Old 01-11-2013, 02:26 PM   #2
1937pickup
Default Re: F150 trans pictures
Did you make the rear plate? It appears it is set up for a torque tube-so it would work on the early flatheads? Great looking tranny.
1937pickup is offline   Reply With Quote
Old 01-11-2013, 02:30 PM   #3
miss victoria
yes cnc machined uses stock rear bells and u joint
Old 01-11-2013, 07:23 PM   #4
Henry/Kokomo
Henry/Kokomo's Avatar
How does the overall length compare with the stock transmission? Beautiful job.
Henry
Henry/Kokomo is offline   Reply With Quote
Old 01-11-2013, 07:27 PM   #5
miss victoria
the driveshaft and tube get shortened aprox 2 inches everything else bolts in.
Old 01-12-2013, 09:23 AM   #6
D. Jones
D. Jones's Avatar
M. V.
I assume this transmission is one you assembled/built from one that was available as original equipment for the F-150. And I'm assuming it is a five speed, is that correct?
I've been thinking that an O.D. transmission would be a great addition to my flathead powered 46 1/2 ton, but haven't been able to find anyone that could tell me if it could be done or where to start. The old Ford car O.D. transmissions are column shift and it doesn't appear to be practical to convert the case of a top loader.
Any information on how this was done would be appreciated.
D. Jones is offline   Reply With Quote
Old 01-12-2013, 10:01 AM   #7
flathead 53
Smile Re: F150 trans pictures
I had one of these in a model pick-up with a worked 32 b ,block a few years ago
flathead 53 is offline   Reply With Quote
Old 01-12-2013, 10:09 AM   #8
Jack 34pu
Jack 34pu's Avatar
Would love one of those transmissions in Lil' Red. I'm a driver and that would put less strain on the flathead out on the road since the rear is 4:11's.
Jack 34pu is offline   Reply With Quote
Old 01-12-2013, 10:51 AM   #9
miss victoria
this is a full syncromesh trans the v8 ratios are 1st 3.0061,2nd 1.7766, 3rd 1.0000 ,4th.7246 o.d.
Old 01-12-2013, 11:36 AM   #10
Dak Rat
Are you going to market these plates?
Dak Rat is offline   Reply With Quote
Old 01-12-2013, 02:03 PM   #11
miss victoria
how much of that did you want?
Old 01-12-2013, 02:26 PM   #12
pineapple
pineapple's Avatar
What year f150 can these trans be found in?
Thanks in advance.
Matt.
pineapple is offline   Reply With Quote
Old 01-12-2013, 02:32 PM   #13
my4dv8
What are these like to drive as first gear is reasonably tall with quite a jump to second gear but 4th looks great.
my4dv8 is offline   Reply With Quote
Old 01-12-2013, 03:22 PM   #14
Bassman/NZ
Bassman/NZ's Avatar
Ford F150, 84-87, some are from 302 V8, some are from inline 6. They are a 4 speed with 4th being overdrive. There are three models all with different ratios. The ratios a fairly similar to a flathead V8, but there is synchro on all gears, and a flathead will never break one.
Bassman/NZ is offline   Reply With Quote
Old 01-12-2013, 09:46 PM   #15
pineapple
pineapple's Avatar
Bassman, thanks, I'll be shakin' the trees and rakin' the leaves to see if I can find one..or two.
Old 01-12-2013, 10:26 PM   #16
Kahuna
Kahuna's Avatar
They were also available in the E-150 series vans
Kahuna is offline   Reply With Quote
Old 01-13-2013, 12:49 PM   #17
Teich
Have one of these trans in a 1948 Car. Got the whole trans set up from Miss Victoria, it looks very nice drives really nice, ratios seem to work better than the original. Have 3.78 gears 60-65mph is great will go even faster if you want. the part I like is looking under the car.... it looks original. I was lucky able to use a 39 driveshaft assy . Laurie
Teich is offline   Reply With Quote
Old 01-16-2013, 03:33 PM   #18
buck36
buck36's Avatar
Ive got a 1936 ford 1-1/2 ton truck with the non-syncro 4 speed. I have been researching doing a T-5 conversion. This seems like it may actually be better. My bellhousing looks different. Can this be made to wotk in my truck?
I Learn Something Every Day...Whether I Want To...Or Not.
buck36 is offline   Reply With Quote
Old 01-16-2013, 04:52 PM   #19
mrtexas
mrtexas's Avatar
There is a LOT more to the conversion like extensive machine work than just a rear plate. After talking to someone that actually does the conversions I concluded that it was much simpler to buy one already done than do what the guy told me has to be done.
mrtexas is offline   Reply With Quote
Old 01-17-2013, 09:05 AM   #20
Dak Rat
Ah, good to know. I'm not a machinest.
