I was looking for the size of the headlight focusing screw in the Standard Hardware booklet. It states the size is: 3/16-32. I always thought 3/16" machine screws were really #10 size, so 3/16-32 would be the same as #10-32. I have never seen 3/16-32 machine screws in stores. I have seen 3/16" carriage bolts. Can anyone confirm or refute whether they are the same or different?
Rusty Nelson |
Rusty, they are the same--or as close as you're going to get.
#12 hardware is bigger. Joe
1929 Tudor since 1962 Feather River A's |
Yep, it amazing how quickly much of what we need is no longer available at hardware stores. I've been running around looking for two #12 x 1" oval or flat head wood screws with a slotted head. Finally found a couple yesterday for 33 cents each with a flat head. I really wanted oval, but still haven't found them. Any slotted head screws are quickly disappearing.
Tom, how badly do you want them? McMaster-Carr has them in stainless.
#12-24 x 1" oval head machine screws Joe
Forget finding them in any store that only sells blister-packaged H-ware.
I've generally had good success with ACE Hardware stores, which tend to stock loose hardware in pull-out trays.. |
Good luck, Paul |
#7 | |
#8 | |
McMaster -Carr is a terrific resource, and they will sell to John Q. Public.
The "old toolmaker" way to determine what diameter rod is used for machine screw sizes is to take the number size and times it by .013 and then add .060. Example for 10-32 is 10 X .013 = .130 + .060 = .190; .190 being close to 3/16 so the #10 screws are that size. The 12-24 screw would be 12 X .013 = .156 + .060 = .216; .216 is just under 7/32.
#12 screws are to big. It seems like 3/16" and #10 are basically interchangeable.
Rusty Nelson |
#12 | |
Cute Trick! I'll remember that one! You are correct, #10s are interchangeable with 3/16, and #12s are 7/32. Little story, I once found an old, large coffee can that was about half full of 1/4-20s 12-24 and 10-32 SS Oval heads among a lot of other stuff for $.50. I didn't realize that the 12-24s were in there till I got it home and started poking around in it. I've never found any since. You get a little lucky now and then.
Terry Quote:
#13 |
[QUOTE=Tom Wesenberg;569633]Yep, it amazing how quickly much of what we need is no longer available at hardware stores. I've been running around looking for two #12 x 1" oval or flat head wood screws with a slotted head. Finally found a couple yesterday for 33 cents each with a flat head. I really wanted oval, but still haven't found them. Any slotted head screws are quickly disappearing.[/QUOTE
Did you try 7 Corners Hardware? They had some pretty cool, off the path, stuff 10 years ago when I used to hit Minneapolis pretty often. http://www.7corners.com/ |
#14 |
You might try Tioga Stainless -lots of hard to find fasteners including oval head :
http://www.tiogastainless.com/ They also come to Hershey in the Fall |
#15 | |
[QUOTE=5window;569921]
#16 |
#17 |
Believe it or not they are located about 3-4 miles from my home & I wasn't aware of them!
#18 |
Tom, not too long ago we had a Trustworthy Hardware store that carried those. It was owned by our local CO-OP. They decided to close it two years ago and I can feel your pain in not being able to find cartian sizes and types of hardware. I wish I would have bought their selection of screws but with the news that the place I was working was closing its doors I was not spending much at that time. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!! |
#19 |
Reading this makes me feel lucky that we have three specialty bearing/bolt/tool stores in the town I live, where I can buy the correct size bolts etc. This is in addition to the hardware stores, and the town only has a population of 14000.
#20 |
| Thread Tools | |
| Display Modes | |
