Old 12-09-2012, 08:16 PM   #1
Wilbur
Wilbur's Avatar
Default Opinions on using a Shortened Pitman Arm
What do you guys have to say regarding using the imported shortened pitman arm to reduce steering effort?
Wilbur is offline   Reply With Quote
Old 12-09-2012, 08:48 PM   #2
Gord. B by the bay
Default Re: Opinions on using a Shortened Pitman Arm
Money well spent i have one on each A Grod B by the Bay
Gord. B by the bay is offline   Reply With Quote
Old 12-09-2012, 09:10 PM   #3
allen
allen's Avatar
Send a message via ICQ to allen
Snyders now sells them, so no cutting and welding all four of my A's have them
allen is offline   Reply With Quote
Old 12-09-2012, 09:23 PM   #4
2manycars
2manycars's Avatar
I cut and welded mine 10 years ago, and I find it to ease steering effort, with no loss of turning radius. I just bought a new one for the coupe. I could have welded another, but a new one was easier.
2manycars is offline   Reply With Quote
Old 12-09-2012, 09:36 PM   #5
allen
allen's Avatar
Totally agree, 35 dollars very worth it.
Old 12-09-2012, 10:02 PM   #6
Wilbur
Wilbur's Avatar
Sounds good. My wife has a hard time with the steering on her 29. Thanks
Old 12-09-2012, 10:52 PM   #7
pat in Santa Cruz
pat in Santa Cruz's Avatar
the new manufactured ones are the safest. There have been failures with welded ones. Even Henry shortened the pitman arm for 1932. Combine it with round spindle balls and the steering gets much easier. If the spindle balls are .020 out of round, they will contribute to stiff steering. A&L re balls the spindle arms the right way so the ball does not break off. With new smooth surfaces you can use the Teflon buttons, AKA EZ steer kit, in the tie rod and drag link ends which will make it even easier to steer..
pat in Santa Cruz is offline   Reply With Quote
Old 12-10-2012, 02:29 PM   #8
Pete
I agree, a short pitman arm is the way to go for easy steering.
However, I have gone the other way with a longer one on my F100 box along with a linear controlled power assist cylinder.
It gives me 3/4 turn lock to lock which is ideal for the type of driving I have come to enjoy most of late. Going FAST down dirt logging roads. I can see why rally racers do what they do.
Old 12-10-2012, 03:11 PM   #9
MikeK
MikeK's Avatar
I tried one on my 40B. Being a light car, I did not feel any significant ease in the steering effort. It did, however make it feel like I was driving a bus with the slowed ratio. I put the stock arm back on. I like the quicker steering and more direct road feel.
MikeK is offline   Reply With Quote
Old 12-10-2012, 03:41 PM   #10
#1modelafan
I have a shorted pitman arm on one of Model A's. I do not find it to make any difference in the required turning effort. Also, now it takes a lot more area to make a U turn. When I get time, I plan to replace back to an original. Lee
#1modelafan is offline   Reply With Quote
Old 12-10-2012, 04:22 PM   #11
Barry B./ Ma.
Barry B./ Ma.'s Avatar
I have a new one on my roadster and it makes it easier to turn. The wheels still turn lock to lock so the radius didn't change.
Barry B./ Ma. is offline   Reply With Quote
Old 12-10-2012, 04:39 PM   #12
Pete
Originally Posted by Ross/Kzoo View Post
An added advantage is that it keeps the drag link separated from the tie rod, no rubbing.
Old 12-10-2012, 04:47 PM   #13
CarlG
CarlG's Avatar
Originally Posted by Pete View Post
Probably caused by a sagging front spring ??
Old 12-10-2012, 04:51 PM   #14
Terry, NJ
Terry, NJ's Avatar
Anyone have any instructions on welding one of these up? Where to make the cut? What rod works best (70/ 8018LH?) Preheat? Cool slowly or quench? I am thinking of drilling it out and putting a 5/16 X 2" rod down the middle, in effect, a spine. Or weld a piece on the back where it can't be seen to bridge over the weld. Jest thinkin'!
Terry
Old 12-10-2012, 04:51 PM   #15
Pete
The drag link is on top of the spindle.
The tie rod is on the bottom of the spindle.
Old 12-10-2012, 04:52 PM   #16
Ross/Kzoo
Ross/Kzoo's Avatar
Yes!
Ross/Kzoo is offline   Reply With Quote
Old 12-10-2012, 05:01 PM   #17
Pete
Yes!
It is physically impossible for the drag link and the tie rod to rub on a stock A front end. Not even if you remove the spring...Not even if you disconnect the drag link from the pitman are and lay the end on the ground. They are seperated by 7 inches.
Old 12-10-2012, 05:13 PM   #18
Ross/Kzoo
Ross/Kzoo's Avatar
Maybe I called it wrong but there was rubbing. I about started from scratch so maybe I did something wrong. I'll post pictures later.
Old 12-10-2012, 05:25 PM   #19
allen
allen's Avatar
Originally Posted by Terry, NJ View Post
Anyone have any instructions on welding one of these up? Where to make the cut? What rod works best (70/ 8018LH?) Preheat? Cool slowly or quench? I am thinkingg of drilling it out and putting a 5/16 X 2" rod down the middle, in effect, a spine. Or weld a piece on the back where it can't be seen to bridge over the weld. Jest thinkin'!
Terry
Terry the way i did mine is cut a v take out 1and 1/2 preheat oven 450 the used cast iron rods build with each pass when done pack it in sand and let cool. done this with three none broke couple of thousand miles on each
Old 12-10-2012, 05:31 PM   #20
MikeK
MikeK's Avatar
Cast iron filler rod on a steel forging? Accident waiting to happen.
