Old 11-04-2012, 08:45 PM   #1
mll1446
Default Is this a t wheel? Has a number with a letter a with circle around it
Is this a t wheel? Has a number with a letter a with circle around it number is 300693 is this a t steering wheel rim is wood and center is metal maybe cast. Iron.
mll1446 is offline   Reply With Quote
Old 11-04-2012, 09:07 PM   #2
jackdaron
Default Re: Is this a t wheel? Has a number with a letter a with circle around it
Looks more like a cheby.
jackdaron is offline   Reply With Quote
Old 11-04-2012, 10:09 PM   #3
mll1446
Why say that
Old 11-04-2012, 10:11 PM   #4
J Franklin
J Franklin's Avatar
It isn't Model T Ford.
Old 11-07-2012, 09:07 PM   #5
Susanne
I think S'heavy olé!! Not a Ford product, anyway.
Susanne is offline   Reply With Quote
Old 11-09-2012, 03:27 PM   #6
Willie in Houston
Willie in Houston's Avatar
The wheel looks a 15" 1918 wood wheel or earlier which were mounted on a steel spider. Later Ford went to a 16" "Fordite" wheel which was mounted on a pressed steel spider.
Willie in Houston is offline   Reply With Quote
Old 11-09-2012, 06:35 PM   #7
yachtsmanbill
yachtsmanbill's Avatar
The dish is inverted. A dead give away! Thats one of the peculiarities of a model T. Even if you see a picture of a driver with a wheel in his hands you can ID it as a T. All bets are off on that one if it were changed for more "lap" room, but thats a dodge or a chevy wheel! ws
" Warning; the following contains content that the anal retentive may find offensive - please skip on to the next posting!"
yachtsmanbill is offline   Reply With Quote
Old 11-09-2012, 08:55 PM   #8
Willie in Houston
You are correct, I did not look at the top mounting on the wood wheel. (not Ford)
Old 11-25-2012, 06:07 PM   #9
oldmotorsguy
Pretty sure that is an early Dodge Brothers wheel, circa 1919 through 1924 or so. I have a photo of my 1923 Dodge Bros. Touring steering wheel, and it's pretty darn close to yours.
oldmotorsguy is offline   Reply With Quote
Old 11-25-2012, 07:42 PM   #10
noboD
All DBs that I know of have 7/8 hole with two opposing keys, I only see one.
noboD is offline   Reply With Quote
Old 11-26-2012, 09:38 AM   #11
mll1446
see addded pics
Old 11-26-2012, 10:52 AM   #12
mll1446
does part number a 300693 mean anything
