Old 11-21-2012, 08:30 PM   #1
SPRYSTANG
Default 1936 speedometer.... 150 mph?
How far up did the speedometer go up to in 1936? Everywhere i look, they only go up to 100 mph, but i was talking to a guy that said he has one that goes up to 150 mph. Seems pretty high for a 36, but maybe im wrong. Just curious if anyone knows for sure, and if they go up to 150, was it only in a certain type of body style? Thanks
SPRYSTANG is offline   Reply With Quote
Old 11-21-2012, 08:31 PM   #2
Fe26
Default Re: 1936 speedometer.... 150 mph?
Is it a European model showing Kilometers Per Hour?
Fe26 is offline   Reply With Quote
Old 11-21-2012, 08:50 PM   #3
SPRYSTANG
No it apparently looks like a normal u.s. Speedometer but goes up to 150! Same design, same needle, same colors, ect.... Im just curious, ive just never heard of it. Thanks
Old 11-21-2012, 08:56 PM   #4
Henry/Kokomo
Henry/Kokomo's Avatar
Could be a custom job. However 150 Km/hr would be close to 100MPH, I think. I never heard of a '36 having a 150MPH speedo either.
Henry/Kokomo is offline   Reply With Quote
Old 11-21-2012, 10:36 PM   #5
DavidG
DavidG's Avatar
Unless it is specifically labelled MPH on the face, it is a metric (KPH) speedometer. The look identical except for the calibration on the face and were manufactured by the same companies that supplied Ford with the MPH speedometers.
Old 11-22-2012, 02:13 AM   #6
ken ct
Never seen one either. ken ct. Got to be KPH/
ken ct is offline   Reply With Quote
Old 11-22-2012, 07:28 AM   #7
ventilo
here's my metric speedo (sorry for the poor quality)
ventilo is offline   Reply With Quote
Old 11-26-2012, 12:13 AM   #8
uncle buck
uncle buck's Avatar
Here are a couple of pics of a 150 kph speedo I have. I also included a mph speedo for comparison. Note the differences in the housing and bezel in the last pic.
uncle buck is offline   Reply With Quote
Old 11-26-2012, 12:27 AM   #9
uncle buck
uncle buck's Avatar
close up
Old 11-26-2012, 01:11 AM   #10
Mike in AZ
Mike in AZ's Avatar
is that kph....or mph.....Mike
Mike in AZ is offline   Reply With Quote
Old 11-26-2012, 01:59 AM   #11
uncle buck
uncle buck's Avatar
kph
Old 11-26-2012, 02:11 AM   #12
ken ct
Cant read it,pretty fuzzy. ken ct.
Old 11-26-2012, 02:35 AM   #13
ford38v8
ford38v8's Avatar
Geeze. And I thought I was blind. You got two choices... It's either a K or an M.
No, you got three choices... Don't try to read it, just believe uncle buck.
You guys, I just don't know about you!
Alan
Old 11-26-2012, 11:24 AM   #14
Bruce Lancaster
Most likely as noted above a metric one, but there is an odd extra possibility: If you look at the little ads in the back of Hot Rod Magazine circa 1952, you will find ads for a little company that reworked Ford speedos: They would recalibrate and re-silkscreen to make a speedo with much higher than stock top speed OR rework your Ford speedo into a tachometer!
One of the speedos has emerged and has been shown on the HAMB.
Old 11-26-2012, 12:02 PM   #15
Mike in AZ
Mike in AZ's Avatar
uhhh, who isn't believing Uncle Buck??....Mike
Old 11-27-2012, 09:03 PM   #16
40grit
40grit's Avatar
This is correct. I bought my roadster out of S Africa. Gauges looked the same as US. 150 KPH is equal to 93 mph.
John L
Just slightly abrasive
40grit is offline   Reply With Quote
