Old 11-20-2012, 08:05 PM   #1
modelasam
Default Mystery Carburetor
I found this carburetor, I don't know what it is. It looks very much like a Tillotson, but it isn't split horizontally and screwed together, like every picture I can find. The body is a single casting with no removable bowl or anything. it is stamped "H-I-F MADE IN USA" Does anyone know what this is, and is it worth rebuilding/ are parts available?
Thanks
modelasam is offline   Reply With Quote
Old 11-20-2012, 08:20 PM   #2
mach0415
mach0415's Avatar
Default Re: Mystery Carburetor
Thanks
It would be helpful to list your location, as there are listings for HIF carbs found in Europe as well... hey ya never know.
Also do you have pics?
Here is a link that may fit: http://www.thefullwiki.org/SU_carburetor
Thanks,
Mark in SC
"We the unwilling, led by the unknowing, are doing the impossible for the ungrateful." -- By society, who is still arguing over who said it.
mach0415 is offline   Reply With Quote
Old 11-20-2012, 08:29 PM   #3
modelasam
I am located in Michigan. I have a picture, hopefully it uploads...
Old 11-20-2012, 08:37 PM   #4
mach0415
mach0415's Avatar
Cool. Yeah that doesnt fit the link, then. FWIW I would just consider a Tilly or Zenith from the cost vs. availability of parts and info aspect. It seems there were several lesser knowns, by todays standards, that were replacements available years ago in the aftermarket.
Thanks,
Mark in SC
Old 11-20-2012, 11:38 PM   #5
modelasam
Thanks! That looks to be correct. Upon closer inspection, the letters are RIF. Since I can hardly find anything about it online, I assume it is not worth trying to rebuild and use, and I should just get a Tillotson or Zenith?
Old 11-21-2012, 08:24 AM   #6
Mike V. Florida
Mike V. Florida's Avatar
Soak it, take it apart and see if there are "common" parts. It would be a conversation piece if you were to get it to work.
Old 11-24-2012, 05:57 PM   #7
modelasam
What is the best penetrating liquid to soak a whole carburetor in? Also, does anybody have any information on this Rayfield? I can only find a few mentions of it here and there. Is it a rare piece?
Thanks
Old 11-24-2012, 07:53 PM   #8
Tom Wesenberg
Tom Wesenberg's Avatar
The new carb cleaners aren't worth much compared to what I used to use in the 60's and 70's.
I'd try Evoporust, since Vince and several others have reported good results with it.
Old 11-24-2012, 08:00 PM   #9
Bob from Northport
Bob from Northport's Avatar
Look in the Restorer Magazine. Sept/Oct. 1995 Page 12. Rayfield carbs.
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 11-24-2012, 09:25 PM   #10
modelasam
Does anybody by chance have that issue of Restorer, and could and post a picture of the Rayfield article? That would be awesome. I have a few issues, but not that one.
Old 11-25-2012, 11:40 AM   #11
Gord. B by the bay
Model A Sam I have and using the RIP carb Made in USA on the side I have used it for 20 some years and never has given a problem, It has a small pump on the side right in the casting and pump the carb twice and it never fails to start. I like the three screw lid you can undo the top to see inside the carb with out taking it off the manifold. It also gives great mileage I have checked it on highway driving 24 mpg. Now that I have gave you the specs on operation would you sell it to me???
Have a Great Day Gord. B by the Bay
Gord. B by the bay is offline   Reply With Quote
Old 11-25-2012, 03:35 PM   #12
Chris Haynes
Chris Haynes's Avatar
What is the best penetrating liquid to soak a whole carburetor in? Thanks
Go to www.kanolabs.com. Buy a gallon of their KROIL. Pour it into a plastic container that has a lid to stop evaporation. Use it to soak any part that needs to be freed up.
Their AeroKroil is also a great spray-on penetrant.
1921 Runabout
1930 Tudor
Early 1930 AA
