Old 07-29-2010, 10:41 AM   #3
George/Maine
George/Maine's Avatar
Default Re: 41 Ford Starting Problem
When you are raising the voltage "ohms law "you lower the current.By cuting out the resister you increase the current to coil.
You could try only a 12 volt resister.You should try to get the voltage running to 3.5 to 4 volts at coil by adjusting the resister size.
George/Maine is offline   Reply With Quote
