Old 10-02-2012, 11:51 PM   #7
Old Henry
Old Henry's Avatar
Default Re: Light switch trouble
Originally Posted by Rand View Post
Kinda related question?? will a bad head light switch cause the head lights to be dim? When I first turn them on they are dim and then they get brighter. Maybe ground problem? (50 Merc)
Thanks..Randy
Originally Posted by Dec211975 View Post
Rand,
It appears you have a loose connection some place that when it gets warm tightens up! I would suspect the ground first but it could be the supply side, you can check both ground and power sides by checking voltage drop with a volt meter, I prefer an analog meter to do this over a digital. Brian
And, you can eliminate the switch and wiring by just running a jumper wire from the battery terminal directly to the bulb to see if it's any better. If so, you know the wiring and/or switch is weak. Then jump over the switch and see if that improves it. If so, it's the switch. If not, it's the wiring. If none of that helps jump to ground from the ground terminal of the bulb and see if that helps. If so, it's the ground. Run a seperate ground wire.
Prof. Henry (The Roaming Gnome)
"It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness
Old Henry is offline   Reply With Quote
