Hey all, I have a 30 Tudor that needs new body mount blocks eventually. I am missing the back ones. Until I by a new set I was thinking of cutting my own to temporarily use.
What is the thickness of the blocks? |
Or maybe a better question; are all the blocks front to rear the same thickness?
The two rear blocks are taller than the others because they fit up inside the subframe rather than under the cross sills. I have some dimensional pictures of the ones used for 1928-29 I can send if you want - I'm pretty sure the 30-31 ones are the same except for their length - believe they were made longer in order to reduce cracking of the subframe. If nothing else this will bump your post up again and maybe someone else can add some info.
Just a thought--Buy the complete set now and use only what you need for now. Save the rest for when you complete the job. They are not that expensive.
Lee |
on my 30 tudor [unrestored orig] they meas. 1 7/8" high X 1 1/2 wide, length is just over the rear cross member.
| Thread Tools | |
| Display Modes | |
