Old 08-31-2012, 08:48 PM   #1
Bruce Compton, Canada
Default rear end interchange
Hi : Can anyone confirm if a 1A ( '51 Ford) 10 bolt pig will fit in my '54 Merc. The current one in the car, (a 4.10 ratio) looks externally identical to the 1A centre section ( a 3.90 ratio). Thanks : Bruce
Bruce Compton, Canada is offline   Reply With Quote
Old 09-01-2012, 12:02 AM   #2
ford1
Default Re: rear end interchange
my interchange book says no doesnt say why
ford1 is offline   Reply With Quote
Old 09-01-2012, 03:01 AM   #3
JeffB2
JeffB2's Avatar
Not positive but I remember hearing about different splines in the spider gears,to verify pull an axle and try it.
JeffB2 is offline   Reply With Quote
Old 09-01-2012, 08:09 PM   #4
O.K. guys, just for the record, the 1A pig fits perfectly in my '54 Merc housing and even the axles interchange (same spline and length). As a bonus the 3.90 gives me a little less RPM at any given speed than the 4.10 and all the niose is gone. I found a Hemmings site that gives all the rear end data for all Fords and Mercs from '32 to '57. It showed that 49-'early '55 Fords were the same as '52-'54 Mercury. Thanks : Bruce
Old 09-01-2012, 08:25 PM   #5
paul2748
paul2748's Avatar
The 54-56 wagons had different rear so it will not fit those.That means that it will probably fit a 55 and 56 also (except wagons and Tbirds)
Old 09-02-2012, 01:15 AM   #6
Alaska Jim
Alaska Jim's Avatar
Bruce, could you post a link to the hemmings site? Thanks, ----Jim
Alaska Jim is offline   Reply With Quote
Old 09-02-2012, 06:59 AM   #7
Jim, I just typed in " Ford rear axles in Hemmings" and the site came up. I don't know how to post a link, sorry. Good luck : Bruce
Old 09-02-2012, 07:27 AM   #8
raceron1120
raceron1120's Avatar
Here ya go - I think this is what you're looking for: http://www.hemmings.com/hmn/stories/...feature30.html
raceron1120 is offline   Reply With Quote
Old 09-03-2012, 02:59 AM   #9
JeffB2
JeffB2's Avatar
EZ to do,when you are on the website you want to post a link from right click your mouse left click on "copy" go to site you want to post it on and in your post click "paste" and that's it.
