Old 08-26-2012, 11:02 AM   #1
NDFlathead
Default '34 drag link
What is the procedure for adjusting the end, large screws, on a 1934 Ford drag link?
Appreciate any help on this matter.
NDFlathead
NDFlathead is offline   Reply With Quote
Old 08-26-2012, 12:28 PM   #2
David J
David J's Avatar
Default Re: '34 drag link
IF your ball studs are perfectly round tighten the screws until you coil bind the spring & then back it out 2-3 turns . This will prevent "DEATH WOBBLE" . If your ball studs are worn some you will need to set this at the tightest point . Usually opposite of it's working position . If you don't do this it will bind when you turn due to the ball being thicker where it isn't worn . Real simple stuff & search "DEATH WOBBLE" . You will see the wobble thing is commom & CUREABLE !!!
NDFlathead
David J is offline   Reply With Quote
Old 08-30-2012, 12:57 PM   #3
NDFlathead
THANKS for your help David.
