Old 08-15-2012, 09:45 AM   #1
glenn in camino
glenn in camino's Avatar
Default spray cans
What's the best rattle can paint for small chassis items?
Old 08-15-2012, 09:52 AM   #2
Tacoma Bob
Tacoma Bob's Avatar
Default Re: spray cans
Been using Krylon since Moses left Egypt in a Model "A" but times have changed as far as chemicals. VHT isn't too bad.
Tacoma Bob is offline   Reply With Quote
Old 08-15-2012, 10:05 AM   #3
CarlG
CarlG's Avatar
Rustoleum Professional
Old 08-15-2012, 10:23 AM   #4
Kevin in NJ
Rustoleum works good but takes forever to dry. For those not going for points, the Rustoleum professional stainless will give you a Cad plate look. You also want the gloss and semi gloss blacks.
Some of the cheap new enamels suck. They go on like water and do not stick to pointy areas. Not worth bothering with at all.
Been doing a lot of small parts with powder coat. Something to look into if you are starting a restoration and have lots of parts to do. Paying extra for Tiger-Drylac is worth every penny as it works much better then the lower cost stuff I have used. I made a oven from the trash larger by adding a metal box off the back and insulating it with fiberglass insulation. Did my wheels with it.
Old 08-15-2012, 10:36 AM   #5
ken ct
I use Rustoleum appliance epoxey in gloss black,1 lite coat and 1 heavier one about 15 min. later. Takes 24 hrs to dry but worth it. Nice hard and impervious to most chemicals including gasoline. ken ct.
ken ct is offline   Reply With Quote
Old 08-15-2012, 11:04 AM   #6
d.j. moordigian
d.j. moordigian's Avatar
Ken,
Does it,when dry, have a high gloss?
Glenn,
Are you asking about, "gloss", "semi gloss" or "satin" finish?
d.j. moordigian is offline   Reply With Quote
Old 08-15-2012, 11:10 AM   #7
Richard Wilson
Richard Wilson's Avatar
Spray cans are by far the most EXPENSIVE way to paint anything, in my opinion. Why not buy one of the small "door jamb" or touch up guns and use the automotive paints that you use in your "big" gun? Rustoleum in a spray can works pretty good if you get in a bind and need a quick fix.
Richard Wilson is offline   Reply With Quote
Old 08-15-2012, 11:56 AM   #8
CarlG
CarlG's Avatar
1. I don't do enough large scale painting to justify the equipment and/or the space for "big" gun painting. For that, there are the "professionals" that can do a much better job that I can anyway.
2. I'm only painting a few small chasis parts as I take things apart and they need painting before putting them back together.
3. The drying time for Rustoleum or other rattle can paints isn't a problem since it's probably going to be several days (weeks) before it gets put back together anyway.
4. If I did use even the small touch up guns with bulk paint, I'd be spending more time cleaning up the equipment than I would painting with it.
5. Even for special mix colors, I can have the paint put in rattle cans for touch-up quite easily and not so expensive, considering all the above.
Old 08-15-2012, 12:15 PM   #9
ken ct
Originally Posted by d.j. moordigian View Post
Ken,
Glenn,
Yes very glossy. Only comes in gloss. ken ct.
Old 08-15-2012, 12:22 PM   #10
joe plumber
I been using Krylon since Hitler was a Corporal ,it's good .Also like Dupli-color .JMO
joe plumber is offline   Reply With Quote
Old 08-15-2012, 01:42 PM   #11
Tom Wesenberg
Tom Wesenberg's Avatar
Smile Re: spray cans
[QUOTE=CarlG;479776]1. I don't do enough large scale painting to justify the equipment and/or the space for "big" gun painting. For that, there are the "professionals" that can do a much better job that I can anyway.
I checked the other day for mixed paint put into spray cans and it was $28 per can. I won't go that route for my 1955 Evinrude. I did find some that was close, but still not close enough for me.
BTW, Tempo used to have good cans of spray paint in spray cans, but I haven't seen that brand fro years. They must have gone out of business, or got bought up by someone.
Old 08-15-2012, 01:48 PM   #12
Jason in TX
Jason in TX's Avatar
I like the appliance paint also. It's a very nice hard finish.
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
Old 08-15-2012, 02:06 PM   #13
CarlG
CarlG's Avatar
Originally Posted by Tom Wesenberg View Post
... Tempo used to have good cans of spray paint in spray cans, but I haven't seen that brand for years. They must have gone out of business, or got bought up by someone.
Try your local friendly Aircraft shops. Here's an on-line source:
http://www.aircraftspruce.com/menus/...ycoatings.html
Old 08-15-2012, 04:42 PM   #14
Kevin in NJ
I have also used my airbrush with the PPG concept. I mix using table and teaspoons. I always seem to mix up 4 times more than I use and the paint usually lays down nice and glossy.
Clean up is quick.
Old 08-15-2012, 04:56 PM   #15
Stretch Cab
Stretch Cab's Avatar
What about Eastwoods Chassis black???
Stretch Cab is offline   Reply With Quote
Old 08-15-2012, 05:09 PM   #16
miss victoria
i use rust-oleum 2x yes dries slow , but after about 1/2 hour i give the parts a coat of rust-oleum specialty lacquer, dries fast and hard. forgot to say clear lacquer
miss victoria is offline   Reply With Quote
Old 08-15-2012, 05:12 PM   #17
CarlG
CarlG's Avatar
Miss Victoria,
What do you use for the engine paint?
Old 08-15-2012, 05:14 PM   #18
MrTube
MrTube's Avatar
I did my best to show the gloss with this picture. This was done using Appliance Epoxy though I think its Seymour brand. First thing I ever sandblasted or spraypainted so cut me some slack on imperfections. The color is bright white, the white balance is off on the photo, but shows the gloss.
https://sphotos-b.xx.fbcdn.net/hphot..._3521454_o.jpg
This picture is more color accurate but doesn't show gloss as good.
https://sphotos-a.xx.fbcdn.net/hphot..._8203012_n.jpg
MrTube is offline   Reply With Quote
Old 08-15-2012, 05:16 PM   #19
miss victoria
Carl, your bellhousing was painted rust-oleum satin hunt club green. not perfect but easy to get.
Old 08-15-2012, 05:19 PM   #20
CarlG
CarlG's Avatar
Thanks
