Old 07-23-2012, 12:28 PM   #1
Bruce
Bruce's Avatar
Default Tinnitus while driving the Roadster
Our '30 Roadster has a distinctive ringing sound that emmanates from somewhere on the dash or in front of it while driving. All attempts to issolate it by pushing on pieces and parts while going down the road have been for naught. The sound is loud enough to be a ring tone on your cell phone. It is not quite as brrringy as an alarm clock, but it is distractingly ringy. My co-pilot agrees that the car is ringing. (It is not something going on in my head.)
This is a lot more annoying than a pop bottle rolling around inside a door. I worry that some piece of 80-year-old sheetmetal is screaming out in stress and is just about to come apart.
Anyone had a similar problem with squeeks, squeels, or rings -- and found the source?
How did you fix it?
Bruce is offline   Reply With Quote
Old 07-23-2012, 12:31 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Tinnitus while driving the Roadster
Could it be the spark and gas rods rattling against the steering column?
Old 07-23-2012, 12:42 PM   #3
Mitch//pa
a dry speedo cable can make weird noises emanating from the dash area
Old 07-23-2012, 12:53 PM   #4
BrianBurkert
BrianBurkert's Avatar
I second the speedo cable theory.
BrianBurkert is offline   Reply With Quote
Old 07-23-2012, 01:05 PM   #5
Patrick L.
Patrick L.'s Avatar
I think I have the same noise, but, it starts at about 45.. I can't find it either and I think its fuel tank/cowl related.. I don't think it'll get fixed until the tank comes out.. I also have tinnitus really bad and that noise is louder than my ears,, irritating..
Old 07-23-2012, 01:33 PM   #6
Gary/IA
Gary/IA's Avatar
My mystery "ringing" noise turned out to be a loose crank hole cover on the radiator shell. It wasn't noticeable when just idling but at times it became loud and annoying.
Gary/IA is offline   Reply With Quote
Old 07-23-2012, 01:41 PM   #7
Aerocraft
Aerocraft's Avatar
Turn the radio up.............
Gar Williams
Aerocraft is offline   Reply With Quote
Old 07-23-2012, 01:57 PM   #8
Deluxe Delivery
Deluxe Delivery's Avatar
The phone type ringing in my town sedan is in the horn button. A slight "laying on "of the finger to the rim of the horn button will cause it to stop vibrating and the phone stops. I believe it is a lacking felt inside the column.
Deluxe Delivery is offline   Reply With Quote
Old 07-23-2012, 02:07 PM   #9
John Stone
John Stone's Avatar
I had one that was the bell shaped cover on the gear shifter.
John Stone is offline   Reply With Quote
Old 07-23-2012, 03:12 PM   #10
Clem Clement
Clem Clement's Avatar
Check your engine pans. They like to contact the frame at some point and raise a ruckus. I have a noise as well and can't find it.
Old 07-23-2012, 03:22 PM   #11
Barry B./ Ma.
Barry B./ Ma.'s Avatar
Check the hood support mounts at the firewall for cracks, just a possibiliy then remove the hood, drive it to se if it is still there.
Barry B./ Ma. is offline   Reply With Quote
Old 07-23-2012, 04:24 PM   #12
WTSHNN
WTSHNN's Avatar
My speedo is to blame for an annoying noise that happens between 37 and 50 mph. I lubed the cable and took apart the speedo and lubed it all up but it still occurs so I'm not sure what it is.
-Tim
WTSHNN is offline   Reply With Quote
Old 07-23-2012, 05:45 PM   #13
steve s
steve s's Avatar
Two particular toughies I had come to mind:
The radiator support rods sang a song at certain speeds, especially backing down. The cure was to wrap a bungee cord around them.
The gas tank filler screen rattled when backing down. Just snugging it up worked.
Steve
steve s is offline   Reply With Quote
Old 07-23-2012, 05:59 PM   #14
Hyperion
Hyperion's Avatar
My phantom is a LOUD rattle that is silent until reaching a certain engine speed (same for all three gears), then eventually goes away at a higher engine speed. Almost sounds like something loose in the flywheel / clutch assy. Like a loose nut or safety wire whipping around. In third gear it will start around 30MPH and disappears at 47MPH. At slower speeds it sometimes will stop if I hit a bump in the road, then starts up again. I've played around with the spark/throttle rods, coil wire protector, pushed and pulled on everything else... Makes it interesting on tours where the group speed is always between 30 and 47!
Hyperion is offline   Reply With Quote
Old 07-23-2012, 07:54 PM   #15
Bruce Adams
Bruce Adams's Avatar
Take the speedo cable out of the shielding, over lube it with liquid graphite through the upper cable shield and then replace it by fitting it into the bottom receiver slot, and lube it some more.
PUFF
Tinnitis GONE !
Bruce Adams is offline   Reply With Quote
Old 07-23-2012, 09:07 PM   #16
RTC1930
RTC1930's Avatar
I need to oil where the front motor mount meets the frame or I get a loud ringing like you describe. I thought it was a bearing squeal but instantly goes away when i add oil to the frame cross member.
Bob NJ
"Fix what's broken"
RTC1930 is offline   Reply With Quote
Old 07-23-2012, 09:33 PM   #17
w.michael
w.michael's Avatar
I cured a similar ringing in the coupe by taking out my hearing aids.
W. Michael
w.michael is offline   Reply With Quote
Old 07-23-2012, 09:34 PM   #18
SSsssteamer
SSsssteamer's Avatar
Last week I found a ringing just as you described. It was the rubber vaccum hose for the windshield wiper that had a vacuum leak. Disconnect the vaccum hose and plug it and see if the noise goes away. Let us know when you find the source of your high pitched squeal.
SSsssteamer is offline   Reply With Quote
Old 07-23-2012, 09:34 PM   #19
columbiA
Loose baffle in fuel tank?You could stick a speaker magnet under the spot welds under the tank.My car has one weld about 6" each side of center that can be felt with the finger.If the baffle is broke on the bottom,the magnet may keep it from vibrating.At the very least, it will catch loose rust particles.
columbiA is offline   Reply With Quote
Old 07-23-2012, 11:11 PM   #20
Drive Shaft Dave
A few years ago there was a story in one of the national club magazines about a similar ringing noise, turned out it was a dust cover from one of the brake adjusters and was rolling around in the brake drum.
Drive Shaft Dave is offline   Reply With Quote
