#11 | ||
By "volt gauge", are you referring to the "Batt" gauge on a '40? If so, a precision 60-ohm resistor is all you need to "convert" it. No changes or alterations to the gauge itself. The factory (instrument reducer) IR is a chopper style. It works too, but again, is a poor choice for gauges, IMO. For original style gauges that used a chopper, it works fine. And will probably work satsifactorily for most folks too, but it's not the most accurate thing in the world and if you buy it new at NAPA (vs scrounging in a junk yard), they're expensive.
Daddy always said, "If yer gonna be dumb, you gotta be tough" and I'm one tough sumbitch! T5 Tech Last edited by Flat Ernie; 07-13-2012 at 07:16 PM. |
| Thread Tools | |
| Display Modes | |
