#61 |
photos
Mechanically Inclined but not Auto Familiar |
#62 | |
http://www.flatheadv8.org/T5Rebuild.pdf |
#63 | |
Generally, if you're installing an drivetrain from scratch, you want a few degrees down. Really, the key is that your crankshaft & transmission output shaft centerline is parallel to the pinion centerline. This is usually accomplished with a magnetic angle finder. Measure the angle of the pinion at ride height. Then fabricate your new transmission mount so the output shaft of the trans has the same angle. Parallel...not pointing at each other. If you do not do this, you may develop driveshaft vibrations and/or destroy u-joints.
Daddy always said, "If yer gonna be dumb, you gotta be tough" and I'm one tough sumbitch! T5 Tech |
#64 |
It appears that I have a damaged second gear and I have to replace the 1/2 slider. My understanding ( after several phone calls) is the slider is available and might be the same between NWC and WC, the second gear is a different issue and may or may not still be available. Any ideas where to start my search?
Positive stops on the shifter or not, what are you guys running?
Mechanically Inclined but not Auto Familiar Last edited by bugsiegel; 07-09-2012 at 07:12 PM. |
#65 |
A lot depends on the way you are going to use it. I don't use positive stops on mine as it is used as a daily driver and a truck. If you are going to race and shift hard then positive stops are the way to go. I gave up on racing many years ago. I could manage the cubic inches but not the cubic dollars!
#66 |
A cheap $50 eBay shifter for a Mustang can be easily modified to fit the S10 shifter box. The rear holes are in the correct place and you need only redrill the front holes and trim the shifter base to fit. Almost all of these Mustang shifters have positive stops.
#67 |
Flat Ernie,
I see some shifters on ebay that have two side screws which limit left right travel but I though that positive stop will prevent a shift back into first from second. I can't seem to find any offered that do just that. Definitely not for 50 bucks. What is positive stop? Or are we just talking about stiffer springs to pull the shifter into the center position quicker/harder? Thanks
#68 |
The positive stops are typically bolts for the forward/backward. It does prevent moving the shifter a certain amount. It is not stiffer springs.
Here's a 'factory' Hurst unit. I think these were used on some of the early SVO and Cobras. Hurst offered them for a while too and then changed the design. This should give you an idea of the concept: http://www.ebay.com/itm/5-0-Mustang-...r#ht_558wt_932 Here's a standard $50 shifter. The stops are not installed in the picture, but the hardware packet has the bolts: http://www.ebay.com/itm/83-04-FORD-M...ht_3141wt_1018 Here's what that $50 shifter will look like with the bolts installed (this is a more expensive shifter): http://www.ebay.com/itm/E-HP-Mustang...#ht_4491wt_821 And here's the $30 shifter: http://www.ebay.com/itm/01-02-03-FOR...ht_2994wt_1160 Same thing as the $50 shifter.
#69 |
finished and painted. I can't install it for a few weeks. The wife is asking me to build a wall unit for the basement play room. I had to finish the trans to clear the counter top for wood work.
Be right back.
| Thread Tools | |
| Display Modes | |
