Old 06-13-2012, 02:29 PM   #1
29ModelA
29ModelA's Avatar
Default Tips for removing dried, stuck rotted windshield seal?
Does anyone have any tips for removing the old seals? I plan to install the new one this weekend and the old one does not want to come out.
1929 Model A Barn find. California car, just a few more parts to find.
Interior, steering box (rebuild), and I am sure much more!
29ModelA is offline   Reply With Quote
Old 06-13-2012, 02:56 PM   #2
V4F
V4F's Avatar
Default Re: Tips for removing dried, stuck rotted windshield seal?
they do that . it takes patience & a ice pick or suitable sharp object to get it out . patience is the key here i think ..
V4f
V4F is offline   Reply With Quote
Old 06-13-2012, 03:01 PM   #3
Richard Wilson
Richard Wilson's Avatar
I have had luck with a 1 1/2 inch putty knife, a blade screw driver that I filed to a sharp edge and a small hammer.
Richard Wilson is offline   Reply With Quote
Old 06-13-2012, 03:15 PM   #4
29ModelA
29ModelA's Avatar
Is it best to do this on the car? I thought about doing the hinge seal at the same time, but am unsure about removing the windshield yet.
Old 06-13-2012, 03:37 PM   #5
Dave in Boise
Dave in Boise's Avatar
leave it in the sun, let it get warm.. spray liberally around the seal with water soluable mineral oil.. the mineral oil softens up rubber very quickly, and after long enough exposure (a week or so) turn to a gooey, gummy substance.. It may be sticky, but should loosen up it's grip on the glass
Dave in Boise is offline   Reply With Quote
Old 06-13-2012, 04:00 PM   #6
Bud BC
I used a heat gun, small putty knife and box cutter blade. Worked great.
Bud BC is offline   Reply With Quote
Old 06-13-2012, 10:43 PM   #7
Russ B
I did my 68A windshield frame about two months ago.
It had delaminated glass, lots of 50 year old silicone sealer, and the groove was a combo of glass, rust, and the seal. I first used a hammer to beat out most of the old glass. Then, I used a putty knife, an ice pick, and a cut down screwdriver.
I did it over a few days, mostly lots of elbow grease, and as the top of the photo shows, lots of fine crud and stringy silicone were still showing up after a day plus working on it. ...then I had the frame sandblasted. Afterwards, my painter saw all the rust through in the channel and suggested I buy/find another frame. My biggest concerns were the bulging rust blistered areas that had been in the frame all these years. When I started, these visibly bad areas looked about the same condition as they had around 1960, so I figured if I clean it up enough, prime it, put in new seal and glass, paint it good; then it should last longer than I will. I was able to get the bulged out rust areas all cleared out and back to pre-rust shape. ..so, I spent another couple days TIGing up rust holes in the channel. It looks pretty good and quite useable now. Just took time and patience.
Russ B is offline   Reply With Quote
Old 06-14-2012, 07:51 AM   #8
29ModelA
29ModelA's Avatar
Sorry this is the seal that seals against the body when you close the windshield, not the seal that holds the glass itself, that one appears to be fine. I am trying to get the seals replaced because I plan to put a roof on it this fall/winter and want to get it sealed back up. Right now the windshield cannot be closed at all.
Old 06-17-2012, 10:54 AM   #9
Tinbasher
Tinbasher's Avatar
I'm working on the windshield frame for my car right now. I used a flat chisel and gently pryed up on the metal flange untill the old hard rubber would come out. From what I can see on mine the factory put the rubber in and then went around the flange with a hammer and a pin punch about every 2 inchs and pinched the rubber in place. Take the windshield out and work on the bench it will be easier in the long run.
The Old Tinbasher
Tinbasher is offline   Reply With Quote
Old 06-17-2012, 11:08 AM   #10
29ModelA
29ModelA's Avatar
The Old Tinbasher
I did the same this weekend, only with it on the car. It took about an hour. I need to put the hinge seal on yet though.
