Old 06-01-2012, 08:29 PM   #1
Franchise_24
Franchise_24's Avatar
Default Water temp?
What is the normal water temperature of a running Model A? I run straight water. Thanks.
Franchise_24 is offline   Reply With Quote
Old 06-01-2012, 08:30 PM   #2
Jordan
Jordan's Avatar
Default Re: Water temp?
mine runs 170* while cruising down the highway in the Texas heat
Cowtown A's
Jordan is offline   Reply With Quote
Old 06-01-2012, 09:08 PM   #3
Jim Parker Toronto
Jim Parker Toronto's Avatar
Mine runs 165 all the time with the thermostat......
Jim Parker Toronto is offline   Reply With Quote
Old 06-01-2012, 09:18 PM   #4
marc hildebrant
marc hildebrant's Avatar
Mine runs about 140 F. This is with straight water and no thermostat.
I would be curious if anyone knows the temp that Ford thought the Model A would run at under "normal" conditions.
Marc
marc hildebrant is offline   Reply With Quote
Old 06-02-2012, 08:42 AM   #5
John LaVoy
John LaVoy's Avatar
140 was what I got before installing a thermostat. We did an investigation regarding operating temperatures needed for optimum fuel burn and that is 160 degrees. Remember when the Model A came out the fuel did not have all the additives etc. we have now so you need to have your engine matching what is being used not what it was originally designed for because those fuels are no long available.
John LaVoy is offline   Reply With Quote
Old 06-02-2012, 12:54 PM   #6
Kurt in NJ
Kurt in NJ's Avatar
Mine ran about 140 without thermostat, put in a 160 thermostat, got 2.5 mpg more with just that change, it is one of the old style thermostats with a big flap and a bi-metal coil, so far 25+ years with no problems, at the time I was changing the hose and had just found the tstat in the trash
If you read the back of a motormeter it says ---"cold motor use radiator cover "in the area under about 160
Old 06-02-2012, 01:58 PM   #7
Michael in Sedona
Michael in Sedona's Avatar
140 to 160, depending on weather and whether I'm driving along or idling in traffic. Running straight water. Have never seen it go above 165.
Michael in Sedona is offline   Reply With Quote
Old 06-03-2012, 10:24 AM   #8
Paul from Maine
Paul from Maine's Avatar
180 degrees with a 180 degree thermostat and brassworks radiatior no mater how warm or cold out it is.
Paul from Maine is offline   Reply With Quote
Old 06-03-2012, 11:44 AM   #9
Franchise_24
Thanks for all the replies.
Old 06-03-2012, 12:46 PM   #10
newshirt
newshirt's Avatar
A club member used a mini infrared themometer on my radiator yesterday. It measured 172 degrees at the top or the radiator and 152 at the bottom. The head measured 185 degrees.
Now I want one of those mini infrared thermometers! (It's smaller than a garage door opener.)
When I first got the car, I worried about not having a temp gauge. I never had trouble, so the worry went away. Now I'd like one of those little infrared units just to play with. What a cool device! (Get it? )
Ray White
newshirt is offline   Reply With Quote
Old 06-03-2012, 01:44 PM   #11
Tom Wesenberg
Tom Wesenberg's Avatar
I bought mine at Harbor Freight. I used it to check transistor temps when I was testing heat sinks on the output transistors of the EVR's I make, as well as checking radiators and brake temps.
Old 06-03-2012, 03:13 PM   #12
Kurt in NJ
Kurt in NJ's Avatar
I bought a little more $$ one from Mastercool that can have an external thermocouple and a range to 2000 degrees -- http://www.tooldiscounter.com/ItemDi...kup=MAS52225-A
then I just saw this-- http://www.google.com/products/catal...d=0COABEPMCMAU
Old 06-03-2012, 03:50 PM   #13
newshirt
newshirt's Avatar
The infrared thermometer I saw yesterday looked something like this. Are these any good?
http://www.harborfreight.com/non-con...ter-93983.html
Ray White
Old 06-03-2012, 04:08 PM   #14
ctlikon0712
ctlikon0712's Avatar
I like this one even better with the temp range and price.
http://www.harborfreight.com/non-con...ter-96451.html
Wanted: Simmons Super Power Head
Craig Likon 1931 150B
ctlikon0712 is offline   Reply With Quote
Old 06-03-2012, 06:45 PM   #15
Tom Wesenberg
That's the one I bought and like, but I only paid about $25 for it 5 years ago.
Old 06-03-2012, 07:22 PM   #16
quickchange
quickchange's Avatar
I have the same one as Tom. Harbor Freight , Great thing for checking temps all over engine & radiator , you will be surprised at the reading, Tryied on the wife but no reading ???
quickchange is offline   Reply With Quote
