Old 07-10-2010, 07:51 AM   #1
36 flathead
Default Re: Erratic problem
did you try swapping out your condenser. I had the same problem on my 36 and that fixed it.
36 flathead is offline   Reply With Quote
Old 08-25-2011, 09:30 AM   #2
Tinker
Tinker's Avatar
Red glad you are doing well with your health!
I had the same problem with my 38pu. Hesitated/bucked under load only. Idled great. But once you take it for a run it would run poorly.
Switch out the condenser ($10), cleaned the points, and rotor contacts. Now it runs like it should.
Good luck!
