Old 07-08-2010, 03:02 PM   #1
Fordlane Wayne
Default Vacuum Gauge Testing
I tested the vacuum on the Model A with a gauge placed in the hole on the intake manifold and have the following reading. The needle rapidly moves 7 inches above and below 20 inches when the car is at full advanced idle speed. It moves around 5 inches above and below 20 inches when the car is running at full retard idle speed. Does anyone know what this is telling me? At high rpm it's pretty steady at around 20 inches. I'm running a high compression head with between 86 to 90 lbs compression in all cylinders. The engine was restored around 1988 and has less than 2,000 miles on it according to my knowledge. Any suggestions would be appreciated. Thank you.
Fordlane Wayne is offline   Reply With Quote
Old 07-08-2010, 11:48 PM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: Vacuum Gauge Testing
check here:
http://www.classictruckshop.com/club...vac/vacuum.pdf
Old 07-09-2010, 12:42 PM   #3
Joop
Joop's Avatar
No one out there to help my buddy?
Joop is offline   Reply With Quote
Old 07-09-2010, 01:04 PM   #4
Bob A.
Here you go joop
"Some Talk the Walk while others Walk the Walk"
Bob A. is offline   Reply With Quote
Old 07-09-2010, 01:07 PM   #5
Bob A.
Originally Posted by Mike V. Florida View Post
Mike, I didn't open your link. Same chart but much clearer.
Old 07-09-2010, 04:43 PM   #6
Fordlane Wayne
thank you all for your help. I found a link that has an "interactive" chart where the pointer in the test gauge moves to show what's going on. Check it out at http://www.secondchancegarage.com/public/186.cfm
Wayne
Old 07-09-2010, 05:28 PM   #7
cars56
Good chart Bob
Posting it in my garage
cars56 is offline   Reply With Quote
