Old 05-01-2012, 07:54 PM   #1
bige386
bige386's Avatar
Default Wolf Whistle.
Just wondering if any of you have a wolf whistle hooked up under the hood. I bought one for my 46 Ford to use it parades and cruises and such. I started to hook it up but there is only one vacuum line that goes to the distributor and I didnt think it would be a good idea to tap into that line. Is there any other spots on a stock 239 to pull vacuum for the whistle ? Would it be wise to drill a 1/8" pipe thread for a hose barb in to the intake ? Or should I just forget it ?
Any thoughts.
bige386 is offline   Reply With Quote
Old 05-01-2012, 08:00 PM   #2
bk53
Default Re: Wolf Whistle.
what year 239? my 53 has a couple of bolt plugs just under the back of the carb in the manifold riser
Bill
bk53 is offline   Reply With Quote
Old 05-01-2012, 08:05 PM   #3
Steves46
Steves46's Avatar
How about installing a T-fitting in your vac wiper line?
If it aint broke, don't fix it!
Steves46 is offline   Reply With Quote
Old 05-01-2012, 08:14 PM   #4
bige386
bige386's Avatar
I don't have vacuum wipers. so thats out.
Old 05-01-2012, 08:16 PM   #5
bige386
bige386's Avatar
My 239 is a 46. I did look around on the intake but I only saw the one tube that runs down to the Distributor.
Old 05-01-2012, 08:32 PM   #6
3quarter32
3quarter32's Avatar
I drilled my intake way back in the seventies. Coated the bit with grease, drilled slow, cleaned bit, greaseed, and drill more. Did this until I had a hole thru, then coated tap with grease and threaded for the whistle. No ill results that I know of.
Lee
3quarter32 is offline   Reply With Quote
Old 05-02-2012, 12:18 AM   #7
Old Henry
Old Henry's Avatar
I bought one of those "wolf whistles" and hooked it up to my wiper vacuum line. It was very disappointing. So disappointing in fact that I immediately took it off and resold it on ebay. Here's the problem with them:
Number 1 - They are not a whistle, they are an itty bitty siren. They do not change pitch as a human produced wolf whistle does, they are only one pitch. Varying the vacuum only varies the volume, not the pitch.
Number 2 - They are pitifully quiet. Two reasons for that: 1. The mechanism that creates the sound is very small. 2. Instead of the sound being projected out of the horn (what a joke) as it would if the air was blown through it, it is sucked into the engine!
Before doing any permanent modifications like drilling a vacuum port into your manifold you really ought to hook it up to some vacuum some way and see if it's what you were really expecting.
I actully had a handheld version of such a "whistle" for many years that I could hang on a string around my neck. But it operated by blowing into it and I could get a lot more pressure blowing into it than 15 lbs of vacuum sucking on one. It was really loud and effective for calling my 10 kids together before we installed intercom in the house. But, sucking with 15 lbs of vacuum does not cut it in my opinion.
Prof. Henry (The Roaming Gnome)
"It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness
Old Henry is offline   Reply With Quote
Old 05-02-2012, 12:26 AM   #8
wolfie
wolfie's Avatar
I had one on a Model A when I was young but I don't know how it was installed, but it was fairly loud.
wolfie is offline   Reply With Quote
Old 05-02-2012, 12:30 AM   #9
dumb person
dumb person's Avatar
This guys one seems ok http://youtu.be/r3ibAF4u4TA that one in the video link. Do they still make them like that?
dumb person is offline   Reply With Quote
Old 05-02-2012, 01:51 AM   #10
ford38v8
ford38v8's Avatar
That whistle in the video is a reproduction, not even an original design.The old ones were red, with a straight pull, not a lever. They had a water transfer picture of a wolf in a tophat. They worked very well, very loud, and were, as John said, variable loudness, which in effect sounds like variable pitch. John's whistle apparently was a reproduction also.
There are two vacuum tubes connected to the driver side of the manifold. The front tube serves the distributor, the rear tube serves the windshield wiper. This tube is the one to T off to the whisle. As you have no original vacuum wiper, the rear port on your manifold may have been plugged.
Alan
ford38v8 is online now   Reply With Quote
Old 05-02-2012, 06:46 AM   #11
Hoop
Hoop's Avatar
Here are some Wolf Whistles. The oldest is the tin bell model at the 8:00 position. The rarest is the one in the foreground with the detachable bell; it's marked "The Submarine-Whistle, Hollywood Super Mfg. Co., LA CAL".
The latest repro's are junk.
(They do change pitch and a "highly-skilled" operator can produce a variety of sounds ... many loud enough to put your hearing aid on standby.)
"But it operated by blowing into it and I could get a lot more pressure blowing into it ... "
Yup, nothing beats hot air.
"Remember that when it comes to intelligence, half of all of us are below average."
Hoop is offline   Reply With Quote
Old 12-18-2012, 10:12 AM   #12
norway
norway's Avatar
thanks for that
i want wolf whistle in my ford 1929 pickup. (im 21 year old)
i'm stuck in norway
norway is offline   Reply With Quote
Old 12-18-2012, 11:45 AM   #13
ken ct
Most later cast iron manifolds only have 1 vacume port . so thats out. ken ct.
ken ct is offline   Reply With Quote
Old 12-18-2012, 07:51 PM   #14
dumb person
Originally Posted by norway View Post
thanks for that
Yeah!
i want one too
<Link> This is how we roll<Link>
"I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob
Outcasts rules of old cars
#1 Fun is imperative, mainstream is overrated
#2 If they think it is impossible, prove them wrong
#3 If the science says it impossible you are not being creative enough.
#4 No shame in recreating something you never had
#5 If it were not for the law & physics you would be unstoppable
Old 12-18-2012, 08:10 PM   #15
bige386
bige386's Avatar
Well D/P I have one that Id be willing to part with.
The Lord is the light--allow Him to guide you.
Old 12-18-2012, 10:21 PM   #16
3quarter32
3quarter32's Avatar
The one I had was very loud. If I could see a horse, I could make it look for the sound. I had a cable pull that would change the sound as the pull varied. It could wolf whistle, yelp, chrip or just about any whistle type sound that a person could whistle. Just like playing a musical instrument, just takes practice. I did take mine apart and rework the movements a bit, which helped out a lot.
Old 12-18-2012, 11:46 PM   #17
ford38v8
ford38v8's Avatar
thanks for that
Hell, I'd settle just to be 21 again!
Alan
Old 12-22-2012, 11:06 PM   #18
boo
i have whistles on 3 of my cars, they are originals, were made by yoder ind. in arkansas, the one shown in pix by hoop.the one w/decal next to the box.speedway sells one now that is in the same box. they are loud and make lot of sounds w/practice. got mine from E yoder
boo is offline   Reply With Quote
Old 12-22-2012, 11:23 PM   #19
Dodge
You could use a spacer plate under the carburetor and drill and tap it.
Dodge is offline   Reply With Quote
Old 12-23-2012, 01:07 PM   #20
bige386
bige386's Avatar
Yeah Dodge....I have thought about that and it wouldn't be hard to do seeing how I'm a tool & die maker by trade. I just done know it I wanted to go through all that just for a wolf whistle. But ya never know.
