Old 04-25-2012, 04:30 PM   #21
Farrell In Vancouver
Farrell In Vancouver's Avatar
Default Re: Balancing Beads
Originally Posted by Drew N. Minnesota View Post
I wish I had known about these before I had my AA truck tires mounted, now I'll have to wait until I get a flat or wear the current tires out.
inex01, I wonder how much good these might do for a large 20"x6.00 wheel/tire, maybe topping out at 45 mph?
Still might be worth a shot. If you do it, please post what you learn as I am a long way from hanging the wheels on my AA and would like to know.
Farrell In Vancouver is offline   Reply With Quote
Old 04-25-2012, 05:08 PM   #22
bogiediver
bogiediver's Avatar
A trick for easier install... get a section of clear tubing that will fit snuggly over the valve stem - zip tie it to the stem. Have the tube long enough to hold half the beads (2.5oz), then use a quick jet of air from an air gun (not too hard) and the beads zip right in... do this twice on each wheel and you'll likely be done in 1/2 hour... Just don't get over zealous with the air gun and have those little bb's all over your garage floor.
Also - there is a place in Crystal Lake, IL that has the correct beads at $60 for 5 pounds + shipping - works out to about $1 per ounce - lots less than the parts houses (car or motorcycle). Do a group buy for your club and save bucks... they really do work.
This is the company that used to supply the name brand, until they started sourcing overseas... I bought a jar from them - nice people...
Subject: Zirconium Beads
If you are using this for wheel balancing, the QBZ-58A would be your choice.
QBZ-58A 1.0 mm $ 60.00/quart
Quackenbush Co., Inc.
Scott Quackenbush
6711 Sands Rd
Crystal Lake, IL 60014
Ph: 815-479-8900 Fx: 815-479-9902
Web Site: www.quackco.com
- bogie
'31 (Mostly) Roadster
bogiediver is offline   Reply With Quote
Old 04-25-2012, 05:19 PM   #23
Bassman/NZ
Bassman/NZ's Avatar
They are used by truckers on semis pounding along at 80mph, so they'll do any size.
FWIW: shotgun pellets work too. Some of the rodders over at the Hamb use DynaBeads, some use shotgun pellets.
Bassman/NZ is offline   Reply With Quote
Old 04-25-2012, 06:43 PM   #24
Bob-A
Bob-A's Avatar
Wink Re: Balancing Beads
I guess if you use the beads in your wheels. It will cancel out ever using
a can of fix-a-flat............
Bob-A
Bob-A is offline   Reply With Quote
Old 04-25-2012, 06:59 PM   #25
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Does anyone have NEGATIVE stories about the "beads??
I'm nigh on to being convinced. I have 5 new tubes to install shortly. Any info on lead shot success & quantities for 6.00 x 16 size? Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 04-25-2012, 09:44 PM   #26
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Bob-A
Can you use Fix-a-flat in a tube?
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 04-25-2012, 10:22 PM   #27
Richard in Anaheim CA
Richard in Anaheim CA's Avatar
I installed "Snyder's" beads in 5 tubes yesterday with a friends help.
The tubes have metal valve stems and we used a small vibrating engraving tool.
We installed 4 oz in each tube using the bottle,tube setup that came with the kit.
5 tubes, clean as a whistle, in less than an hour. I had been dreading the job but it was a piece of cake.
That's one job finished for the long drive to Marquette MI.
Richard
Anaheim CA
Richard in Anaheim CA is offline   Reply With Quote
Old 04-26-2012, 08:02 AM   #28
Tom Wesenberg
Tom Wesenberg's Avatar
Bob-A
I've never had luck with that stuff and find it only makes fixing flats a real mess.
Old 04-26-2012, 08:14 AM   #29
Bob-A
Bob-A's Avatar
Cool Re: Balancing Beads
Tom & Brent,
I always carry a can of fix-a-flat in the saddle bags of my Harleys. Only tried using it once and it did not work. The tube had a long rip in it I found out later. However, I have talked to people who have had success
with the stuff. When you are in the middle of nowhere on a bike with a flat tire anything that will get you going is most helpful.
Bob-A
Old 04-26-2012, 08:54 AM   #30
BRENT in 10-uh-C
Tom & Brent,
Bob-A
Their (Fix-a-flat) website says it is not for use in bicycle, motorcycle, and Z-rated tires. You are very correct in that when in desperate need, folks do desperate things. Like you, if I have a flat I am willing to try anything!!
BRENT in 10-uh-C
Old 04-26-2012, 12:17 PM   #31
Ron Lowe
I always keep a bottle of Slime in my Harley bags. I've had two flats on the road and it worked both times and I do have tubes in my bike. You also need a way to inflate the tire. I carry 4 Co2 canisters and a adapter to re-inflate. I might add that one flat had a huge nail in the side wall and Slime still worked. I noticed recently at Wal Mart that Slime makes it in a can like Fix-A-Flat. That would make the flat fixable with Slime and also inflate the tire. The price was about $5 Ron
Ron Lowe is offline   Reply With Quote
Old 04-26-2012, 06:07 PM   #32
Bob-A
Bob-A's Avatar
Thumbs up Re: Balancing Beads
Ron,
Thanks for the info., I'll have to check it out.
Bob-A
Old 04-26-2012, 07:34 PM   #33
Gary Gregory
Gary Gregory's Avatar
I just installed the beads in my front tires...if it did anything it made them worse. Put one 4 oz pack..didn't help, added 1 oz and they seem to bump more than ever. Guess thats what i get for buying the latest ''snake oil''
Gary Gregory is offline   Reply With Quote
Old 04-27-2012, 06:33 AM   #34
BRENT in 10-uh-C
Gary, I'm sorry to hear that. Whose beads did you use, and who did you get them from??
BRENT in 10-uh-C
Old 04-27-2012, 07:01 AM   #35
mjm1972
Can anyone please explain what you are all talking about and maybe post a pic or even link to the parts?
Thanks
mjm1972 is offline   Reply With Quote
Old 04-27-2012, 07:05 AM   #36
VWJoe
VWJoe's Avatar
Bill, I never cared for them. We did a police vehicle fleet test on police crusier's when I worked for Fairfax County here in Nor Va. Everytime the cruiser stopped, the wheels had to re-balance themselves. Not good when the officer had to go code 3 from a stop light. NASCAR guys use them [DynaBeads] to keep from throwing lead off their wheels at 200 mph. They are at a constant speed (no stop & go) and probaly worked OK for that applacation
VWJoe is offline   Reply With Quote
Old 04-27-2012, 05:35 PM   #37
BRENT in 10-uh-C
Jeez, are we really comparing Apple-to-Apples here?
Can you imagine 'Code III' in a Model-A??
I'd say your test came back pretty accurate with your cruisers. They probably did not work well in a fast acceleration setting. I would also think that fast acceleration is not a necessity with most Model-A owners either so maybe that won't be a detriment in our applications. In your defense, I DO realize what Bill asked but then again, ............
BRENT in 10-uh-C
Old 04-27-2012, 09:01 PM   #38
Gary Gregory
Hey Brent, I got the beads from Snyders. My tires "Firestone'' ran pretty good wthout balancing but figured i could make things a little better with the beads. Now the tires bounce at 35 -40mph...right where i drive the most ! Thought about adding a small amount more but wonder if I'm adding to the problem ?
Old 04-27-2012, 09:36 PM   #39
BILL WILLIAMSON
One poster said they thumped on first take off, then smooth. If you then stop for someone's "Granny" crossin' the street, will they thump again??? Gotta' re-think this, 'cause when you put them in TUBES, they're there to stay!!
If you're running tubeless, you could dump them out, pay for mounting & balancing, and tell yourself, "Self, I'm stupid, I should have just flushed $150.00 down the toilet for amusment!!"
I'm just thinking, if this was so GREAT and foolproof, NO ONE in the tire world would be doodling around with balancing weights! Bill W.
