Old 07-06-2010, 10:44 AM   #1
Frank The Plumber
Default Carb fun, Runs like junk out of the blue.
Having a nice weekend all pretty and purring nice, out of the blue runs like junk, Leaking fuel out of the carb body, she must be flooding. And she is.
Took it all apart today, 4 th time in 2 months, This is an edelbrock 4 barrel 800, modern but all the same principals apply, carb tech has not advanced drastically in the last 60 years, Lot of residue in the bowl, both sides, dark hard residue, clean everything out of the bowls, go after the floats, the brock is just like an old carter, has 2 needle valves set in bodies, if you unscrew the bodies there are very fine filters in there, they were both full of residues, a lot of it, just for sniggles and bits I sent a stainless brush for faucets into the fuel rail that interconnects the valves, I pulled out a lot of what appeared to be sands, although I must admit it could have easily been decomposed rubber product. That"ll do it, after cleaning I reassembled her and problem solved.
To the root of it, Im not sure what this stuff is, casting sand? rubber from my hoses, but it sure gave me symptoms of what a lot of you guys seem to be going through, for my part I have a nice fuel system, a high quality holley pump for racing, Aero quip fuel lines, Aero quip fittings a nice holley regulator a brand new drake stainless tank, A really nice Fram cannister filter, I blew 150 psi air and fuel washed all of my hose as I installed it.
My one weak spot in the system is a fuel filter at the carb itself after all of the hosing, that is my recommendation to you guys with troubles. clean it very thoroughly and install one.
Frank The Plumber is offline   Reply With Quote
Old 07-06-2010, 10:59 AM   #2
Old Redneck
Old Redneck's Avatar
Send a message via AIM to Old Redneck Send a message via Yahoo to Old Redneck
Default Re: Carb fun, Runs like junk out of the blue.
My carb was doing that so I sent it to Charlie in N.Y. and he has a fast turn around and now the little ford runs super. He does super work. he done several carbs for me and I wouldn't go anywhere else.716 440 8952
Old Redneck is offline   Reply With Quote
Old 07-08-2010, 08:12 AM   #3
treb11
The alcohol in fuel today deteriorates rubber that is not compatable. Thanks EPA
treb11 is offline   Reply With Quote
Old 07-08-2010, 08:20 AM   #4
jdl
jdl's Avatar
Send a message via ICQ to jdl
With the new fuel system you have I can't imagine where that crud came from? do you think you got some bad gas from the station? I guess if the car was stored for a long time the gas will turn to crud. glad you fixed the problem. good luck to you.
jdl is offline   Reply With Quote
Old 07-08-2010, 03:54 PM   #5
Henry/Kokomo
Henry/Kokomo's Avatar
I put a small filter between the fuel pump and the carb to trap as much roaming crud as possible. Might be worth a try in the interest of preventing future problems. Just a thought.
Henry/Kokomo is offline   Reply With Quote
