Old 03-28-2012, 01:31 PM   #1
Chris
Chris's Avatar
Default Needle and seat hang up on Stromberg 97
I have a new engine in my 34 roadster with two 97 carbs on it. It runs great...but when it sits for more then a day, when I fire it the forward carb starts pouring fuel out of the top of it (vent hole). I can tap on the top and then it is fine. I have taken the needle out and inspected it, cleaned it, ect. Still does it...anyone have any other cures? Would float level have anything to do with it? It is only the forward carb
Thanks, Chris
Thee Inland Emperors
Chris is offline   Reply With Quote
Old 03-28-2012, 02:05 PM   #2
Jason in TX
Jason in TX's Avatar
Default Re: Needle and seat hang up on Stromberg 97
Is the needle the rubber tipped one? I've always heard to use the metal tips
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
Old 03-28-2012, 02:42 PM   #3
40Coupe
I learned why the air horn of one of my 97's had been crushed with a hammer ( I think my Dad was involved many years ago ).
Anyway happened to me a couple of times with pressure regulator at 2.5 psi. I moved down to 2 psi and have so far have avoided the trauma of gasoline spilling down the intake manifold..
Do you have a regulator?
Lane
40Coupe is offline   Reply With Quote
Old 03-28-2012, 03:00 PM   #4
uncle max
uncle max's Avatar
New Stromberg "S" jet fuel inlets will cure it once and for all!
RIP Tyler... My Son, Helper & Best Friend.
Feb '78 to Father's Day '10.
www.97-express.com ~ [email protected]
uncle max is offline   Reply With Quote
Old 03-28-2012, 03:19 PM   #5
Chris
Chris's Avatar
What are those?
Old 03-28-2012, 03:46 PM   #6
ken ct
Its a Grose-Jet 2 balls in it or you canuse a fitting with a steel needle in it[a little cheaper i think] either type is good. Max has them or me. ken ct. I would use same in both carbs. you will have to reset the float.
ken ct is offline   Reply With Quote
Old 03-28-2012, 04:11 PM   #7
37slantback
Chris, attach a little hammer to the manual throttle linkage.
37slantback is offline   Reply With Quote
Old 03-28-2012, 06:34 PM   #8
Mike51Merc
Mike51Merc's Avatar
Chris:
I see from your photo that your bell crank linkage is set in a straight up position at rest (idle). I found that setting mine like that causes the throttle plates to be out of sync when you open them because of the geometry. Take a look down the carbs as you work the throttle open and you'll see what I mean.
I set my bell cranks at around 10 o'clock at idle to cure the problem. They swing from around 10 to 2 o'clock (if they point upwards like yours).
Mike51Merc is offline   Reply With Quote
Old 03-28-2012, 06:58 PM   #9
ken ct
Originally Posted by Mike51Merc View Post
Chris:
Thats a good point Mike,should be at a 10 to 2 swing. 10 at throttles closed. ken ct.
Old 03-28-2012, 07:06 PM   #10
ken ct
Me too Mike 10-2. ken ct.
Old 03-28-2012, 07:43 PM   #11
40Coupe
I had flooding issues even with the new inlets...certainly worth a try I suppose (my humble opinion).
Lane
Old 03-28-2012, 07:50 PM   #12
quickchange34
quickchange34's Avatar
Alot of the suppliers carry the Gross Jets. They work great.
quickchange34 is offline   Reply With Quote
Old 03-28-2012, 08:08 PM   #13
ken ct
What are you useing for a fuel pump?? ken ct.
Old 03-28-2012, 08:11 PM   #14
Chris
Chris's Avatar
I am not using a regulator and I rebuilt an original Ford furl pump that I am using. I will mess with the clock position on the arms.
Thanks guys!!
Old 03-28-2012, 08:13 PM   #15
Pete
I have been using the neoprene tip needles since they came out in the 50's..I like them because you can run the fuel pressure up to 5 lb and then the bowls don't run dry at full throttle...Assuming you have something other than a stock engine.
I have never had one leak. Many modern carbs use them so there must be
something good about them.
If you don't like this type of needle, you can always go floatless.
Old 03-29-2012, 12:33 PM   #16
Mike51Merc
Mike51Merc's Avatar
Hey Chris,
I see you also have the same ignition wires and Rajah clips as me. Copycat!
