Old 03-20-2012, 04:05 PM   #1
Russell in Tulsa
Default Re: Starting issue
Do you have a fuse or power shut off other than the key? If you have a disconnect was it turned on? Check and see if the fuse is good or bad. Put the accelerator pedal to the floor and try to start it without the choke and let it spin several revolutions and let up on the pedal and it may start. Let us know what you have tried as mentioned in the earlier posts and report back.
Good luck. Russell
Russell in Tulsa is offline   Reply With Quote
Old 03-20-2012, 04:20 PM   #2
Franchise_24
Franchise_24's Avatar
Good luck. Russell
I won't be able to check it out for about 24 hours so 6pm "ish" tomorrow, so I will report back and let everyone know if I get it running or not. Thanks for all the suggestions.
Neal
Franchise_24 is offline   Reply With Quote
