#1 | |
Also, to re-tighten those bolts, how do you gain access to the top of the bolt to hold it while you attempt to tighten the nut when the fender is covering the bolt head? Maybe I am wrong but it don't seem too practical to remove the headlights & wiring, the headlight bar, radiator apron and the fenders just to be able to put a wrench on that bolt head!! Maybe I am overlooking something and if so, I apologize in advance for my ignorance in this. . |
#2 | |
) Bill W.
#3 | |
. Have to use the torch to remove it, at least here on the east coast![]() Joe,,, |
#4 | ||
Bill, we use "242" (Blue) Loctite here in the shop but it is not made to be re-tightened once it has been cured. By serviceable, all that means is someone can use regular wrenches to remove the fastener as it is the lightest in gripping power. Also, I think you will find that their "271" (Red) is actually a stronger in gripping power over their "Blue" and is considered permanent. "Green" is actually the same strength as Blue but it wicks into the threads meaning you do not need to disassemble the fastener to apply it onto the threads. Its use is for already assembled fasteners. . Quote:
. Last edited by BRENT in 10-uh-C; 03-09-2012 at 12:01 PM. |
#5 | |
And when you're working with it, be sure that no one slips it in your Kool-aid! (I know a guy that this actually happened to) lolJosh
"The Assistant to the Assistant of The Guru of Stuff" |
| Thread Tools | |
| Display Modes | |
