Old 03-05-2012, 09:19 AM   #1
Steve Wastler
Steve Wastler's Avatar
Default Interesting A on the 'bay'
here is a link, http://cgi.ebay.com/ebaymotors/?cmd=...28319127#v4-43
Steve Wastler is offline   Reply With Quote
Old 03-05-2012, 09:35 AM   #2
bogiediver
bogiediver's Avatar
Default Re: Interesting A on the 'bay'
A Model 'A' Excursion...
- bogie
'31 (Mostly) Roadster
bogiediver is offline   Reply With Quote
Old 03-05-2012, 09:51 AM   #3
real550A
real550A's Avatar
In some odd way, I like it! Would be the only one everywhere you go! Nice delivery
truck for some small business.
Eight more days until our "virgin" '31 coupe gets here, or I'd be tempted to play with this one.
Mike B.
Model A's and Porsches since 1957
real550A is offline   Reply With Quote
Old 03-05-2012, 10:27 AM   #4
Steve Wastler
there is a picture of an AA delivery in brattons catalogthat has a very similar body, it appears the one on ebay had the exreme rear removed from the body, but i too think it would be neat...
Mike, i havent been able to post many pics, but have put a few in an album, i have decided to clean mine up a little. will post more pics later. Cant wait to see a few more picks of yours....
Old 03-05-2012, 10:41 AM   #5
real550A
real550A's Avatar
Steve- Just checked out your pics. A little cleaning helps you define what you've got. That's one beautiful survivor! Looking forward to more detailed body/interior pics. Mike
Mike B.
Old 03-05-2012, 11:06 AM   #6
1930artdeco
1930artdeco's Avatar
Looks like they did a really nice job extending the body-at least from the pics. Would be a neat restoration as a commercial body style.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 03-05-2012, 11:42 AM   #7
Kevin in NJ
One one hand it looks like something grafted to the a tudor body.
You can see they kept the belt molding through to the doors. It looks like the beading over the rear fenders stops about at the top of the fender arch.
The confusing part is the door integration. The door has the flat belt molding, but clearly it uses the original hinges and door latch.
The stampings just look like later commercial and it appears the one rear window is partially rolled down. If that is the case it was intended for passenger service.
Hopefully someone on the board buys it and reports back
Old 03-05-2012, 12:00 PM   #8
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Yeah, I'm with Kevin on this as I was looking at it it earlier this morning thinking it definitely has some unusual panel work going on. A lot of trouble to get working windows in the rear for flowers , ...however for me, it tends to give me an eery feeling for some reason. Maybe just the mood I'm in???
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 03-05-2012, 12:19 PM   #9
real550A
real550A's Avatar
I found this company during a search....maybe one of theirs?
http://www.coachbuilt.com/bui/a/albright/albright.htm
Mike B.
Old 03-05-2012, 12:44 PM   #10
Logan
Logan's Avatar
Is it just me, or does it look like a Hearst?
Cowtown A's
Logan is offline   Reply With Quote
Old 03-05-2012, 12:54 PM   #11
mjw
mjw's Avatar
Patty or Rudolph?
Either way I like it.
mjw is offline   Reply With Quote
Old 03-05-2012, 02:21 PM   #12
CHuDWah
CHuDWah's Avatar
I’m thinking it’s parts of two 28 – 29 Tudor bodies joined to a 31 cowl. Looks like one body, including doors, was cut off behind the rear windows. The other was cut off in front of rear windows and welded on. The second body was cut off behind the rear windows, the flat door panel welded on, and the wheel wells filled. The thing I’m not sure about is whether the hinges on 28 – 29 doors match up to those on a 31 cowl.
CHuDWah is offline   Reply With Quote
Old 03-05-2012, 02:37 PM   #13
Farrell In Vancouver
Farrell In Vancouver's Avatar
The rear doors remind me of a Jeep wagoneer or something, but neat car anyway
Farrell In Vancouver is offline   Reply With Quote
Old 03-05-2012, 02:39 PM   #14
azmodela
It's two Tudor bodies mated together.
azmodela is offline   Reply With Quote
Old 03-05-2012, 03:04 PM   #15
CarlG
CarlG's Avatar
The "Hearse" that Ford built was built on a AA chassis, and does not look anything like this one. Doesn't mean that this one wasn't used for that purpose, however.
Old 03-05-2012, 03:14 PM   #16
700rpm
700rpm's Avatar
Maybe it was the last car Randolph rode in.
Ray Horton, Portland, OR
Old 03-05-2012, 03:16 PM   #17
real550A
real550A's Avatar
Two twodoors put together, no doubt. The rear doors just don't look right. Wonder if these have been changed at some point. The coachwork probably looked good as new, and could again. I'm thinkin black with Tacoma Cream wheels.
I'd prefer the curves of the sedan at the rear, with a sedan delivery type, one piece door.
Mike B.
Old 03-05-2012, 03:23 PM   #18
ctlikon0712
ctlikon0712's Avatar
31 splash aprons, could be coach work, not a one off Frankenstein.
ctlikon0712 is offline   Reply With Quote
Old 03-05-2012, 04:19 PM   #19
Steve Wastler
im with mike would look good with a regular delivery door rear section
Old 03-05-2012, 09:01 PM   #20
CHuDWah
CHuDWah's Avatar
The bodywork looks well done but I doubt it’s coach-built. A coach-builder might have used the cowl but they likely would have built the body from scratch rather than using the Tudor bodies. And the abbreviated rear wheel moldings and the flat rear panel are a little crude for coachwork. I also don’t think it was built as a hearse or flower car. The wheels and rear bumper look to be late-40s/early-50s. While they could have been installed at any time, they may indicate when the car was built. Besides transporting the deceased, a funeral home’s vehicles are rolling advertisements of the business. An undertaker would want, and probably could afford, something newer and nicer than a pieced-together Model A. I think it is a one-off built by a body man or a talented amateur for someone’s personal use or possibly small business.
