Old 02-28-2012, 08:18 PM   #1
brum1
brum1's Avatar
Default Ammeter bounce-normal??
Running 10 amps at 30 mph (8 with the cowl lights on) ammeter bounce +/- 2 amps (about) Is this normal or can it run steady as a rock? Don't notice light flicker or any other electrical issue but wonder if something may be on the edge
"no one knows more than everyone"
brum1 is offline   Reply With Quote
Old 02-28-2012, 09:41 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Ammeter bounce-normal??
That's pretty normal. When I restore the ammeter, or have it out and the cover off, I always lube the 2 pivot points with thick gear oil. It lubes and dampens the needle shake.
Old 02-29-2012, 09:04 AM   #3
JBR
JBR's Avatar
Tom,
Define thick gear oil? 600W?
Thanks,
Jon
JBR is offline   Reply With Quote
Old 02-29-2012, 10:58 AM   #4
Purdy Swoft
Purdy Swoft's Avatar
I guess it depends on how much bounce. I have found that weak brush springs or an out of round commutator will cause the needle to bounce. Sometimes bounce can be caused by brushes not properly fitted to the commutator. In some cases I have reached in and held pressure on the brush while the engine is running and let the brushes wear in to the commutator, rather than disassembling the generator that somebody else has worked on. This practice can be dangerious if your finger gets caught up in the generator. I am always careful. Using a screwdriver to hold pressure on the brush can cost you an armature if it slips and cuts the wires where they enter the segments.
Old 02-29-2012, 11:11 AM   #5
Tom Wesenberg
Originally Posted by JBR View Post
Tom,
Thanks,
Jon
Yes, 600W if I have some handy. If not, then the heaviest oil at hand.
Old 02-29-2012, 11:39 AM   #6
RonC
RonC's Avatar
Hook up a modern analog meter to compare. Also 10 amps is a little steep if you do a lot of daytime driving. You can go as low as 3 amps if you are pretty much limited to daylight driving and you use your car all summer.
RonC is offline   Reply With Quote
Old 02-29-2012, 04:38 PM   #7
brum1
brum1's Avatar
Guys-thanks for all the feedback-guess i will back it down a few amps as most of my driving is during the day
