Old 02-01-2012, 11:15 PM   #1
oljoe001
oljoe001's Avatar
Default my alternator that look like a generator
Thought I would post this as well
oljoe001 is offline   Reply With Quote
Old 02-01-2012, 11:53 PM   #2
hardtimes
hardtimes's Avatar
Default Re: my alternator that look like a generator
Very nice/more original looking than my alternator!
If it weren't soo expensive, I'd have one! Mind telling us where you purchased yours?
Old 02-02-2012, 12:07 AM   #3
msmaron
msmaron's Avatar
What is the function of the cut out or is it a dummy??
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 02-02-2012, 07:52 AM   #4
oljoe001
oljoe001's Avatar
Yes the cut off is a dummy I am going to make a better one just havent found an original cut off yet. As far as the alternator it is a mini race alternator and I built the housing and used an original generator back but drilled the holes larger for air flow.
Old 02-02-2012, 07:54 AM   #5
oljoe001
oljoe001's Avatar
I might mention if you will take a close look at the front you can see just a little bit of the alternator I was going to cover it but was afraid it wouldnt cool enough.
Old 02-02-2012, 08:13 AM   #6
AL in NY
AL in NY's Avatar
oljoe01, do you have any information on where you purchased the "mini race alternator", the make and model number. Looks like the generator case slips over the "mini alternator". More details would be very helpful.
AL in NY
AL in NY is offline   Reply With Quote
Old 02-02-2012, 08:42 AM   #7
Richard Wilson
Richard Wilson's Avatar
Your conversion might be worth a "how to" write up for one of the Model A magazines.
Richard Wilson is offline   Reply With Quote
Old 02-02-2012, 08:43 AM   #8
Mike V. Florida
Mike V. Florida's Avatar
I could not agree more!!
Old 02-02-2012, 08:55 AM   #9
oljoe001
oljoe001's Avatar
Hi Al, the alternator can be purchased off of eBay they make them 40, 50, 80 ,100, amp all the same size just type in Mini alternator mine came from DB electrical , the generator cover I made in my fabrication shop you have do some cutting on the alternator Which will void the warranty and some welding on the back bracket, also had to build a new bracket to hold the housing and alternator. the only part of the generator is the back. by the way our trucks are the same color
Old 02-02-2012, 09:01 AM   #10
Modelakid31
Send a message via AIM to Modelakid31
So cool
Modelakid31 is offline   Reply With Quote
Old 02-02-2012, 09:05 AM   #11
MrTube
MrTube's Avatar
My concern is the fan on the alternator pulls air through the alternator and blows it out of the front via the edges of the fan / impeller. It looks like your case covers most of the edge of the fan?
MrTube is offline   Reply With Quote
Old 02-02-2012, 09:23 AM   #12
John/CT
John/CT's Avatar
You can buy 'em here.
http://www.gener-nator.com/
(no affiliation)
John
John/CT is offline   Reply With Quote
Old 02-02-2012, 09:31 AM   #13
AL in NY
AL in NY's Avatar
John/CT, not the same as oljoe001's homemade genernator. At $86 bucks on ebay for the mini alternator, it's a dame site cheaper to make one then purchase the commericially made genernator at $800+.
AL in NY
Old 02-02-2012, 11:32 AM   #14
Rowdy
I wonder how much work it would take to put one in a powerhouse case. I might look into this further later this year. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 02-02-2012, 11:42 AM   #15
Tom Wesenberg
Tom Wesenberg's Avatar
I was thinking the same thing for those who want an alternator.
Send me your good powerhouse internals.
Old 02-02-2012, 12:24 PM   #16
Richard Wilson
Jeff's right. I love my alternator except when I have to raise the hood. It looks out of time and place.
Old 02-02-2012, 12:32 PM   #17
MrTube
MrTube's Avatar
I don't know, I've always liked the look of an alternator. When I see a generator the first thing that comes to mind is "limp"
Old 02-02-2012, 12:40 PM   #18
Louis
When I go to the lcl. car shows I only open the right side of the hood any way, so my alt. is out of site. The other reason I like to leave the left side closed is one show I went to last sunner some one pulled my oil dip stick out and when they put it back in they did not squeze the handle in and when I got home I had oil on the fire wall and around the dip stick hole.
To me the alt. is far better then the org. gen. jmo
Louis is offline   Reply With Quote
Old 02-02-2012, 12:45 PM   #19
oljoe001
oljoe001's Avatar
Hi this unit has an internal fan and no obstructions from the front, I drilled out the back of the original generator cap for ample airflow.
Joe
Old 02-02-2012, 12:46 PM   #20
oljoe001
oljoe001's Avatar
Hi It wont fit I made the case it is in.
Thanks
Joe
