Old 02-01-2012, 04:31 PM   #1
Randy
Randy's Avatar
Default What cleanout plugs for Merc crank?
I just had my Merc crank turned and want to remove the old plugs to clean it out. What's the best thing to plug the holes back up with? Are they like small expansion plugs or is it best to drill and tap? Thanks.
Randy is offline   Reply With Quote
Old 02-01-2012, 04:42 PM   #2
OLD...BILL
OLD...BILL's Avatar
Default Re: What cleanout plugs for Merc crank?
Randy: Drill and tap, I think 3/8 pipe and use allen plugs, makes it so much nicer next time, you refresh, balance and line bore the mains, too.... OLD....BILL
OLD...BILL is offline   Reply With Quote
Old 02-01-2012, 04:57 PM   #3
Ol' Ron
Ol' Ron's Avatar
I think Reds had some aluminum pipe plugs.
Old 02-01-2012, 06:59 PM   #4
Karl Wolf
Karl Wolf's Avatar
I use Dorman plugs, 555-010... Press in... These are made for this. I use a tapered ream to clean off the old peen spots, locktite them, peen them in place...
Karl
Karl Wolf is offline   Reply With Quote
Old 02-01-2012, 07:16 PM   #5
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
The Merc plugs are 5/8 the Ford 3-3/4 cranks have 3/8 plugs. I think Job Lot has the original plugs, there about 5/8" or so long. Walt
Old 02-01-2012, 07:18 PM   #6
quickchange34
quickchange34's Avatar
Randy you dont need to drill them. Clean them out reall good and use a 1/4 pipe tap and put your allen plugs in with red locktite. You will sleep better.
quickchange34 is offline   Reply With Quote
Old 02-01-2012, 07:38 PM   #7
rotorwrench
rotorwrench's Avatar
Originals were P/N 8CM-6307. They wer listed a 41/64" diameter at 11/16" long. Believe it or not, I found a set on e-pay one time.
Kerby
rotorwrench is online now   Reply With Quote
Old 02-01-2012, 10:36 PM   #8
flatjack9
flatjack9's Avatar
Like Carl, I use the Dorman plug. Never had a problem.
Old 02-02-2012, 07:29 AM   #9
JWL
Say yes to the Dorman plugs. Don't even think about using 1/4" pipe plugs. The only thing they might plug would be the interior of a Dorman plug. WAYYY too small!. Depending on your level of precision any plugs, other than the original style Dorman, could send you to the balancing shop.
JWL is offline   Reply With Quote
Old 02-02-2012, 09:13 AM   #10
jdl
jdl's Avatar
Send a message via ICQ to jdl
Karl
I found the Dorman at my local Carquest Autoparts. they fit many makes & years. they are a tight fit. you can also get them from Red's Headers.
http://www.dormanproducts.com/da-32575-555-010.aspx
http://reds-headers.net/index.php?ma...ankshaft+plugs
jdl is offline   Reply With Quote
Old 02-02-2012, 12:28 PM   #11
GOSFAST
GOSFAST's Avatar
This is fairly straight-forward with the Merc cranks, no drilling is necessary, only tapping the existing holes for some 3/8" NPT plugs! Most OEM plugs come out with a "body-dent-puller" (as seen in the photo below)!
We do every one with this procedure, never went back to pressed pieces!
We also do the Ford shafts as well, but these need drilling! Definitely more labor intensive!
Thanks, Gary in N.Y.
P.S. Just be certain a fairly new tap is used, the crank material is reasonably "tough"!
GOSFAST is offline   Reply With Quote
Old 03-07-2013, 07:28 PM   #12
Walt Dupont--Me.
I get them at Napa, both the Ford and the Merc ones. I can get the Dormon part no. tomorrow. Walt
Old 03-08-2013, 12:16 AM   #13
bobH
As someone posted above... Dorman 555-010. However... Re-use the originals. Tap them (no drilling), slide-hammer them out. When you put them back in, stake. My engine-builder has been doing them this way for years.
(I've got a few of the Dorman plugs, for 'just-in-case'. I've had them for quite awhile, and have never had to use them.)
bobH is offline   Reply With Quote
Old 11-06-2015, 03:27 PM   #14
papanomad
papanomad's Avatar
what is the dorman number for the 3/8" plug?
papanomad is offline   Reply With Quote
Old 11-06-2015, 05:07 PM   #15
jetmek
I haven't had any luck getting those small plugs....those I have been tapping 1/4 pipe if I recall correct
engine and component overhauls my specialty!
Website- www.godevilgarage.com
jetmek is offline   Reply With Quote
Old 11-06-2015, 07:05 PM   #16
oldford2
oldford2's Avatar
Use Dorman plugs. 555-010. Available at CARQUEST and NAPA. If you use the drill and tap for a pipe plug, you better be sure you get every little chip out from that process or risk a scored bearing. JMO. John
oldford2 is offline   Reply With Quote
Old 11-06-2015, 08:58 PM   #17
Bored&Stroked
Bored&Stroked's Avatar
If you use the standard press-in plugs (as shown above) and then put in your nice high-pressure pump, and then run heavy oil . . . you should think about putting a little "pean" mark on the outer edge of them to hold them in (along with locktite).
I've had these blow out before . . . and there goes all your oil pressure . . . and then your bearings!
This is why I now have all the plugs replaced with a screw in plug - usually aluminum (so it doesn't throw the balance way off). I sleep better with screw in plugs . . . and they can easily be removed to clean out the rod throws.
Old 11-07-2015, 03:28 AM   #18
HP Hunter
This is how its done. But steel plugs are fine they have no affect on changing the balance.
Harry
HP Hunter is offline   Reply With Quote
