Old 01-15-2012, 07:08 PM   #1
Max
Default Oil leak
My 33 pickup leaks oil from the rear of the engine. My guess is worn main bearings combined with the labyrinth seal is the culprit.
Any other reasons do you think?
Thx,
Max.
Max is offline   Reply With Quote
Old 01-15-2012, 07:40 PM   #2
Brendan
Brendan's Avatar
Default Re: Oil leak
my 36 leaks also. it has a 35 motor, maybe you have two much oil in the motor, if i have over 4.5 qts in it, it leaks like a sieve
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 01-15-2012, 07:46 PM   #3
Jack E/NJ
Jack E/NJ's Avatar
More likely the seal between the grooves in the rear main cap and pan. They sometimes get twisted, cracked, etc. When this happens you get a lot bigger leak than the customary leak of the labyrinth. I use a neoprene seal glued to the pan groove to lessen the possibility of it getting twisted during assembly.
Jack E/NJ
