A man in my club made a spacer out of wood. The main problem is that you will have to re-engineer the choke/gav rod connection as the rod will no longer line up with the carb. The man said that the spacer did help with the gasohol boiling / vapor block problem on hot days on his coupe.
| Thread Tools | |
| Display Modes | |
