Can you use the stock valve seats if they are in good shape or do you need new seats for the oversive valves thanks
If you have the 8BA block with the cast in seats yes, you can grind or cut in seats for the 1.600 valves. The 59AB with the pop our seats it's a little harder, I've done it but you should pop out the seats and have a shop cut the block for the 1.600 seats. Walt
You won't see a difference in 1.5" or 1.6" on the street.
R |
I'm with Ronnie... The performance difference is going to be at rpm beyond what I would ask my engine for
Karl |
Me too!
no
R |
Well, that's clear! "no" what? L
#9 | ||
You don't want the 1.600" valves "seating" at the very outer edge of the existing seats, not a real good move!! I would also add this, in order to take full advantage of the larger valves you need to do some internal porting, not just the bowls, but the runners as well. Thanks, Gary in N.Y. P.S. Just for comparison purpose here, over the years when we did this procedure, 1.500" to 1.600" on the SBC's, we've found very little gain in power until we ran the units over 5000 RPM. In short, until that rpm band is approached, the 1.500" valve platform will get the job done! |
36tbird, I'm not sure what the engine gurus who have already posted here are going to tell you since some have already said don't bother to use the 1.6" valves.
When I built my 59 engine I used the Chevy valves (1.6 int., 1.5 exh.) because I wanted to install new inserts anyway and the longer stems worked OK with the cam and adjustable lifters I used. The Chevy valves were readily available, are advertised to give better flow around the upper stem area, and were less expensive than the NOS Ford valves that I priced. If i had gone with the logic that 1.6" valve are no improvement over 1.5, them maybe I should have just left the bore stock, forgot the lighter Ross pistons, the L-100 cam, the stroker crank and all the other little things that were done with the hope of getting an overall better performing engine.
#11 | |
#12 | |
. I'll try to find my receipts for all the parts I bought for this engine build and get back to you with a PM.
#13 |
If you are seeking the part number for the 1.5 valves, it's the exhaust valve used in the small block Chev from 1955, until I don't know- all the way thru 350 V8... TRW number is s2090... I don't have listings, so I don't know the 1.6#, I think it's a box stock exhaust for a later Chev V8... I like the Manly brand, or a similiar knock off, for the cut down stem...
Karl |
#14 |
OK, let me ask another dumb question. Aren't the exhaust valves the more critical as far as metallurgy? I mean, an intake valve gets cooled but an exhaust valve takes more abuse because of the exhaust gases, right? Therefore, why can't you use 1.5" Chevy exhaust valves for both intake and exhaust on a flathead and therefore have the same size valves as stock except for the longer stems. Please show me the error of my ways, oh learned ones.
#15 | |
That's what is normally used, and Manley SS undercut 1.5" or 1.6" Chevy exhaust valves with chrome stems are hard to beat.
#16 | |
R |
#17 |
Heck, if I'm gonna lie, I'll just say it's massively re-worked and I put 2 inch Chevy valves in it.
#18 | |
Going to some 5/16" stems will further help! Thanks, Gary in N.Y. P.S. Keep in mind, the 1.500" valves will support 160+ HP (N.A.) below 4500 RPM. If you believe you are going to want higher HP or a higher RPM band, then at that point you will most likely need larger valves! |
#19 |
Obviously the problem with making horsepower in a flathead is flow both in and out through some very convoluted passages. I'm with JM 35 sedan. I used the 1.6 Manley Chevy valves and lots of port work. There are three ways to get gasses into or out of an engine; volume, velocity, or pressure. I'm not running a blower so pressure is out. Velocity is an impossibility in a flathead because of all the turns creating high pressure zones. The only route left is volume. The additional room around the diameter of the valves plus the reduction of the stem to increase flow near the valve have got to help some. Argueably there could be some reduction in torque with reduced velocity at low speeds but flatheads are basically tractor motors; little torque monsters as were most engines of their day. Can you overflow an engine? Of course. Ford fans have to look no farther than the FoMoCo muscles engines of the late 60's/early 70's. Boss 302's and 429's were street dogs. Every roundtracker knew about epoxying up the intake passages on 351 Clevelands to increase intake velocity. But overflow a flathead? I don't think it's possible.
Just my two cents.......... |
#20 |
Installing larger valves in an engine has been a long tine racing practice and I agree using an expensive racing valve MAY add something to the performance of your engine. However there is aalso another reason for using a larger valve, a bad seat. From late 40 through 53 Ford did not usr a hardened seat under the intake and sometimes this area was in poor condition. Which could be solved by installing a hardened seat or using a larger valve. The 1.6 valve from PAW was an inexpensive soultion. For my sterrt engines I would undercut the valve at a 20 degree angle to improve breathing. AS been said here I don't think installing a 1.6 valve in an engine with a hardened seat because the seat may come loose causing major damage to the reat of the engine. I recommend the use of the 1.5 Chevy valve in both the intake and exhaust in any engine with a small base circle cam in a street engine, should last forever.
| Thread Tools | |
| Display Modes | |
