11-12-2011, 11:10 PM
#22
Re: Cant keep my Model A running.. Help me troubleshoot!
- In Step #1, the breaker point gap is the space between the end of the little silver arm (the breaker point arm), and the tiny adjustable screw, under the black plastic disk (the rotor). It was a bad moment for me when I didn’t even know what the book was talking about in the first step.
- In Step #2, a really good tool for bending the rotor tab up or down without marring it is a big crescent wrench.
- In Step #5, when it says to “fully retard the spark lever on the steering column” that means push it all the way up.
- In Step #7, when you have reversed the timing pin and are feeling for the small recess in the cam gear, keep in mind that it is very small, it takes two full rotations with the crank to get back to the same point on the cam gear, and the small recess will be there when the rotor is pointing roughly toward the front of the car. For me this operation took a good deal of time and a LOT of patience. I hope it is easier for you. While you can only turn the crank in one direction, if you go past the notch just a little bit you can grab hold of a fan blade to go back a bit.
- In Step #14, when I tightened the cam locking screw, I had to turn the cam a little farther counter-clockwise than I wanted it to end up in order to account for the movement of the tightening screw.
- Don’t forget to screw the timing pin back in, and remove the crank before you try to start the car
