SOME WHILE BACK, A THREAD DETAILED HOW TO USE SPRAY PAINT TO FINISH GARNISH AND DASH THE COLOR OF MAROOM OR SOME OTHER COLOR. i KNOW THE PAINT MIGHT HAVE BEEN KRYLON AND TO USE A DARK COLOR AS BASE. ANY ASSISTANCE APPRECIATED / JOSH
Josh, if authenticity is not important to you, then use any really dark Maroon spray paint in a can. There is no need to base it with any other color unless you are trying to mimic mahogany woodgraining.
Josh,
I was in on that thread awhile back. It was started January 28. Search for "Town Sedan window moulding". Here is the procedure I used and listed in that thread. Thanks. I think I remember how I did it. 1. Spray on primer 2. Spray on Burgundy color enamel (I used Ace Premium enamel) 3. Hand brush black acrylic (from hobby shop) 4. Lightly brush with a dry paper towel until you get the texture you want. If you take off too much, apply some more acrylic and re-brush with towel. Don't let the towel get saturated - replace with a dry one. If careful, you can get the grain texture right up to the inside corners. 5. Final coat with auto clearcoat or spray clear enamel. 6. Hand rub to gloss finish. As I remember that was how I did it. Remember, if you don't like it, start over or paint over it. Have fun!. I look forward to seeing your results. I highly recommend you give it a try. If it looks terrible, paint over it but if successful it looks so much better than plain paint. |
29 FORD, THANKS FOR INFOR. i WILL TRY AS U SUGGEST...WHAT IS THE BLACK ACRYLIC ? IS THAT IN A SMALL JAR? WILL IT COME OUT LIKE WOOD GRAINING? JOSH
It would be nice to have mahogany woodgrain but need some advice..perhaps dark brown base prime then red maroon of some kind then brush altered so it duplicate grain.josh
Josh there are many methods to wood grain. The method that 29FordGuy mentions is easy & works well. I have wood grained three cars using this method. I use acrylic water base artists paints available at most art or craft stores. These colors come in small tubes & are very thick. They can be mixed or can be combined with a small amount of each color only partially mixed giving a multi color streak. I use a small piece of sponge cut from a larger piece but a wadded paper towel or cheap brush with the bristles cut to diff. lengths works also . The beauty of this method is you can continue doing it until you like your results. It may take 10-20 tries before you like the look. Simply use a damp rag to wipe off the water based paint try again. Once you like the results spray with a clear coat over the water based acrylic. I use clear Varathane spray as it holds up very well. I did a 37 Chevy 5W cp. over 25 yrs ago & it still looks great.
You can play around with an old molding or piece of flat material. I have found the hardest area is the corners. Good luck & have fun!! |
Don't forget the "How To" Model A Woodgraining article by Bill Reeder that is reprinted in MAFCA's How To Restore Your Model A Volume 2 pages107-109. If you have the bucks you might want to check out the "Grain-It" woodgrain kits that are advertised in most of the restoration type magazines.
| Thread Tools | |
| Display Modes | |
