First, I apologize for treading over old territory, but a friend asked. What is the formula for the home brew penetrating oil? Will it last in storage?
Thank you in advance for your assistance and patience.....LouB.
I use 50/50 acetone and ATF. Works pretty good. The trick to any penetrating oil is patience and perseverance.
What he said. That's the answer.
Building a 29 Sedan on 32 chassis........ very slowly....
Gotta keep it in a covered container or else the acetone evaporates. Good stuff.
Thanks guys, asking for a friend who was having issues posting.....LouB.
MIKE
#7 | |
Acetone evaporates very-very quickley, fuel oil and trans fluid works Better. Better yet, Buy a can of PB Blaster, No Muss, No Fuss, and it works as good as Anything.
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN What I GOT DONE TODAY... I got the rear-end put in the recliner, and now I'm going to rest up & watch TV.
I have to go with the 50/50 mix. I had a lathe with a 3 jaw chuck and it wouldn't come off. I tried everything I could think of including a torch and 6' bar. My frienf George suggested actone&ATF. Squirted alittle on it every morning for a few days and it finally screwed off by hand. Great for removing exhaust guides.
i need to try the 50/50 mix with some grease in there....so that it wont evaporate so quickly, maybe you squirt it the area and then put the grease over it..
I used the 50/50 mix on my stuck 8RT cylinders. Everyday I took a crow bar and pryed on the flywheel resting it on the bellhousing alignment pin. After several days I saw a little movement, then a little more each day. Finally I was able to turn it 360°.
It works! Shadetree
Son, you will never blow an engine up in high gear. |
| Thread Tools | |
| Display Modes | |
