Old 09-06-2011, 06:47 AM   #1
Mike51Merc
Mike51Merc's Avatar
Default Re: I need some help- circuit breaker question 6V vs 12V
Originally Posted by Frank Miller View Post
You're close. Volts x Current = watts. A 58 watt bulb requires 8amps at 6 volts. But 4 amps at 12 volts. The filament will have a higher resistance on the 12 volt bulb to limit the amps. Everyone else is right in that the circuit breakers only see current and do not care about voltage as there is no resistance until they surpass the current rating. At that point the bimetalic strip will curl from the heat and open the circuit. The two metqals have different expansion rates which cause it to curl.
Frank, you're theoretically correct (but arithmetically flawed). I was treating the devices as constants because I didn't want to further complicate matters.
Mike51Merc is offline   Reply With Quote
Old 09-06-2011, 08:30 AM   #2
fourtydlx
fourtydlx's Avatar
Send a message via Yahoo to fourtydlx
Any of you elec. wizards know how to lower volts out of a12 v battery maintainer to put on 6v battery? thanks
fourtydlx is offline   Reply With Quote
