Old 08-13-2011, 10:57 PM   #1
'29wagon
Default e break cross shaft grease fitting
who is replacing with what ?
before i put the splash shields back on, maybe i should replace the two grease fittings on the frame.
i did a search on this topic to no avail.
proper way to remove, can i just tap for a small fitting or resize the hole and tap for larger ?
maybe there is a catalog kit.
'29wagon is offline   Reply With Quote
Old 08-14-2011, 08:47 AM   #2
Steve Wastler
Steve Wastler's Avatar
Default Re: e break cross shaft grease fitting
The fittings are a press fit, hex sided (if original), if this is on a 28-30 e brake . I usually put a wrench on the fitting get it to turn some and pop it off, a little help with a screwdriver can help. Brattons sells them under grease fittings in the catalog.
Steve Wastler is offline   Reply With Quote
Old 08-14-2011, 12:10 PM   #3
'29wagon
thank you steve.
i'll give it a turn . i will be replacing these with a modern . i do see the originals listed in the catalogs .
