Old 07-31-2011, 05:05 PM   #81
ford38v8
ford38v8's Avatar
Default Re: uncle gave me a 37 ford coupe
Right up.
Alan
Old 07-31-2011, 05:10 PM   #82
bart78
bart78's Avatar
Thanks. Just trying to make a list of things that I might have from some other old fords I have.
bart78 is offline   Reply With Quote
Old 07-31-2011, 05:18 PM   #83
ford38v8
ford38v8's Avatar
Not being a hotrodder, I'm not sure how to go from the floor shifter to the open driveline if you use the 9".
Anyone?
Alan
Old 07-31-2011, 05:24 PM   #84
bart78
bart78's Avatar
I found on craigs list a guy that has a full 39 sedan rear end and a full 39 front end suspencion and all. He wants 150.00 each. Tryed to call this morning did not get a answer. Thought about getting them and just getting the fron axle droped and lower the rear. He allso has a 39 flathead a trans for 300 says it turns over.
Old 07-31-2011, 05:33 PM   #85
ford38v8
ford38v8's Avatar
Craigslist... beware. See the stuff in person and see the engine run if you can. $300 for the engine is core price, so pull the heads and examine head surface for cracks.
Sounds like you're getting excited here, so it's best to join up with a Mentor from the EFV8CA. Join the National, and join a local Regional Group near you. The old guys will gather round like flies on cowpies when you tell them you want to build a car. The join-up cost is nothin' to the money you'll save benefitting from other's "been-there-done-that."
Alan
Old 07-31-2011, 05:38 PM   #86
bart78
bart78's Avatar
I will look into that. There really is not anyone in my are that even messes with these cars. The closest place that would have anyone is probably an hour or so. But i will see what I ca find. Thank you for being so helpfull.
Old 07-31-2011, 05:39 PM   #87
Tinker
Tinker's Avatar
I remember seeing this posted on the hamb. Did you pull it out of the field yet?
Old 07-31-2011, 05:43 PM   #88
bart78
bart78's Avatar
Not yet. Just waiting for it to cool down. Its been so hot here they are saying 107 all week. Plus the snakes are real bad this year. When It cools down some I will get it. Just looking for parts.
Old 08-01-2011, 11:08 AM   #89
HotRod40Deluxe
Originally Posted by bart78 View Post
What all doors will fit this car? Is it 37-40 coupe? Or will some doors from a sedan work?
Bart,
1937-40 coupe doors are identical as far as the exterior skin, hinge locations, latch and dovetail locations but with the exception of the outside door handle mounting area, which is basically the same for 1937-39. More differences are on the inner door surface re; window regulator mounting hole locations, inner garnish moldings, etc. but can all be found and used. 1940 had vent windows which required provisions and mounting brackets for the vent division bar.
1937-40 sedan delivery and fordor sedan front doors seem identical, but they have a little more lip at the very top-rear corner to match the longer roof line, however I've seen modified sedan delivery and fordor doors be made to work on coupes just fine. 1937-40 tudor sedan doors are out, as they are considerably longer horizontally.
HR40D
HotRod40Deluxe is offline   Reply With Quote
Old 08-01-2011, 11:16 AM   #90
HotRod40Deluxe
Bart,
HR40D
Old 08-01-2011, 11:52 AM   #91
Tinker
Tinker's Avatar
Yep, hot here too. Winter will be here soon enough. In tx, like fl, that is the time to get out and work.
Good luck with your car and watch out for them snakes!
Old 08-01-2011, 01:04 PM   #92
bart78
bart78's Avatar
Will do, this morning I was out there and he was showing me all the 37 parts he had been buying because he allways thought it was a 37. Whats bad about the parts the barn they were in burnt and they were all in it. There is nothing there to use any more because it real hot. I was hopeing there would be some stuff to use or trade or sale. There was all kinds of stuff doors 37 hood sides all the stainless for a 37 all the window molding stuff the wind sheild and trim stuff for it. There was allso a new rad and a few other parts. Sad to see that stuff either melted or full of hole there was a little left of a 37 grille but not much.
Old 08-01-2011, 04:32 PM   #93
fordscript
fordscript's Avatar
An interesting thread, by the look of the photo from the front, it would appear that this is a right-hand drive car. The bottom of the firewall shows the half-circle cut out for the steering column on the right side, and the left side is straight (apparently). Also the number plate bracket holes are on the right side. Definitley a 38 standard, the rear photo confirms this.
fordscript is offline   Reply With Quote
Old 08-01-2011, 05:34 PM   #94
bart78
bart78's Avatar
There is still a clutch and brake on the left side.
Old 08-01-2011, 09:45 PM   #95
bart78
bart78's Avatar
Can someone tell me if a front end off a 39 sedan a nd the rear end out of a 39 sedan will work on my coupe. I would think it would but wanted to check before I made a offer on them. I plan on getting the front axle dropped.
Old 08-01-2011, 10:27 PM   #96
ford38v8
ford38v8's Avatar
Bart, Yes, it's a pretty straight bolt-up. You will need to change out the clutch/brake to that of the '39, and run brake lines, as the '38 was cable and the '39 was juice. Originals are pricy, so also consider repops.
Alan
Old 08-01-2011, 10:31 PM   #97
bart78
bart78's Avatar
thanks i will make him an offer. To lower the rear a bit I can remove a few leafs cant I ? I dont want to make a lowrider but would like it to sit a bit lower.
Old 08-02-2011, 08:09 AM   #98
biggeorge
biggeorge's Avatar
HotRod40Deluxe is dead on with the info on the doors. I have 39 four door doors on my 40 coupe and they fit great after you trim the rear edge at the top of the door. The 39 front and rear should slide right under that frame as the frames are the same from 1935-1940 (almost).
biggeorge is offline   Reply With Quote
Old 08-04-2011, 12:37 AM   #99
Randy Williams
Hi Bart, It looks like you have 38 ford coupe check out the fire wall 37 and 38 are different. You do have a 38 fire wall and the rear fenders look like 38's. The front fenders are hard to tell apart except for the extra bolt hole on 38's.
Randy Williams is offline   Reply With Quote
Old 08-04-2011, 10:19 AM   #100
bart78
bart78's Avatar
I was allways told the car was a 37. My uncle got it long before I was born. I am 32 he said he has had it for 40 years and just never got to it. Now I am on the hunt for parts. I am going this weekend to look at a front end a nd rear end off a 39 sedan. And I found a grill on ebay.
