Old 07-30-2011, 01:58 PM   #61
bart78
bart78's Avatar
Default Re: uncle gave me a 37 ford coupe
After looking up th number its a 38. It only has one place for a tail light. I have no idea why it has a 37 hood. Allso were they 2 tone the body is green and the fenders are black.
bart78 is offline   Reply With Quote
Old 07-30-2011, 01:59 PM   #62
TonyM
TonyM's Avatar
Does your uncle have another old car and does he need another nephew?
TM
TonyM is offline   Reply With Quote
Old 07-30-2011, 02:01 PM   #63
bart78
bart78's Avatar
He has a few more no more fords just a few old buicks. He use to have some real good cars. had a 40 ford conv. And a few other old fords from the 30's I know one was a 34 5 window.
Old 07-30-2011, 02:57 PM   #64
Kentf1003
Welcome to the Barn.
Sure, there's work ahead (pack your lunch). But, what a great model to start with. You have a diamond in the rough.
Kentf1003 is offline   Reply With Quote
Old 07-30-2011, 03:11 PM   #65
ford38v8
ford38v8's Avatar
Bart, Your '38 Standard Coupe had a 60 HP engine originally. The serial number is valid, as you discovered, and is about 1/3 through the 1938 production. The body and frame is the same as used for the 85 HP engine, but if any driveline components remain, you will have to replace them if you want to run an 85 HP engine.
You may rejoice that your license lite door somehow escaped being cannibalized, even though it is sometimes hard to find. It is still bright of course, because it is stainless, not chrome. Your bumper brackets also survive, this being equally puzzling, as they literally take a beating and are also kinda hard to find. Your coupe owes it's survival to the fact of it's small engine, as with the large V8, it would have been destroyed on the dirt tracks years ago.
Edit: I should have said that the transmission, if there, would need to be replaced. The differential, while usable, will be a 4.44x1 ratio, worthy only for parades today.
Alan
Old 07-30-2011, 03:30 PM   #66
bart78
bart78's Avatar
There is no trans or rear end. I have a 9 inch out of a old bronco I was going to use. I allso have one out of a 51 f1 but i dont know if it will work probably go with the bronco. I have a flathead and trans out of a 47 coupe. and will look for a 4 inch drop front axle. Does Bob drake sale a whole quarter panel for the 38? That baler did a prety good job on the passenger side.
Old 07-30-2011, 03:56 PM   #67
bart78
bart78's Avatar
There is allso not anything that looks like there was the stainlees running down the side of the car. I allso saw on craigslist a front end off a 39 sedan and a rearend out of a 39 sedan, they have the brakes and all on them. These will work wont they? And could get the axle droped.
Old 07-30-2011, 05:07 PM   #68
bart78
bart78's Avatar
Was told by someone that this was not a 38 they said the wipers were on the top not on the bottom like this one. The things sticking out at the bottom dont turn like wipers and the one hole above the drivers side is not a bullet hole and i have seen pis of some with one wiper.
Old 07-30-2011, 07:01 PM   #69
TonyM
TonyM's Avatar
The 1938 standard hood looks similar to the 1937 hood.
There is a really nice photo of a 1938 Ford Standard Coupe on page 199 of the 1932-1938 Ford Production Book by DeAngelis and Francis.
TonyM.
Old 07-30-2011, 07:11 PM   #70
ford38v8
ford38v8's Avatar
Bart, Pay no attention to your "someone". He can't tell windshield wipers from windshield cranks.
Alan
Old 07-30-2011, 07:41 PM   #71
bart78
bart78's Avatar
I wont I prety much figured they were not from what they looked like. Going to order drake catalog tonight so I can look for some sheetmetal. The hood look kinda alike, but the 37 rounds off smooth and the 38 has like a rounded step.
Old 07-30-2011, 07:53 PM   #72
TonyM
TonyM's Avatar
One wiper and 1937 type hood.
TM.
Old 07-30-2011, 08:05 PM   #73
bart78
bart78's Avatar
All the 38 standards I have seen have a differant hood. Maybe its an early one and they used up 37 parts. The car allso does not have the stainless on the sides like the others.
Old 07-30-2011, 10:17 PM   #74
bart78
bart78's Avatar
Does bob drake make a whole quarter panel for the 38 like the 40 he has on his web sight?
Old 07-31-2011, 12:33 AM   #75
ford38v8
ford38v8's Avatar
A likely reason for the '37 hood would be that the '38 hood had been damaged by the hood prop unique to '37 & 38. The prop is a ratchet type, requiring the hood to be lifted slightly before lowering it to close. Gas jockeys never got the hang of it and most hoods broke at the weakest point, right at the prop. Your '37 hood may have been intended as a replacement which never got installed due to the difference between the two hoods. Examine the hood you have, and if it is not broken at the driver side near the rear, then you have a very valuable part to barter for parts you do need.
Alan
Old 07-31-2011, 07:11 AM   #76
bart78
bart78's Avatar
You can tell that at some time that someone patched something on the drivers side other than that its in real good shape.
Old 07-31-2011, 07:54 AM   #77
bart78
bart78's Avatar
Thanks guys for the help finding help around here will not happen for cars like this. The only thing people are interested in around here is all their diesels. Not many old cars being redone around here.
Old 07-31-2011, 04:34 PM   #78
bart78
bart78's Avatar
Will a stock floor pan work with me going to use a trans out of a 47 ford that the motor and trans I have came out of or will I have to change it?
Old 07-31-2011, 04:51 PM   #79
ford38v8
ford38v8's Avatar
It will fit, but yours has 3 on the floor, a '47 is 3 on the tree. Best that you trade the later tranny for an earlier floor shift. A '39 is best, as '38 and '37 synchros aren't as smooth.
Alan
Old 07-31-2011, 04:57 PM   #80
bart78
bart78's Avatar
I will look for one. That trans will bolt right up to the motor I have?
