Old 05-28-2026, 08:15 AM   #1
old31
Default Re: LEDs for parking lamps
That will not work. The photo shows dual filament, but the description says:
Rebaydo 2pcs BA15D 6 Volt 60 SMD 5730 "Single Filament" Reduced Profile.
Made with total 60 leds, 44 side firing and 16 forward firing. This lamp is a "single filament" bulb.
old31 is offline   Reply With Quote
Old 05-28-2026, 08:52 AM   #2
Badpuppy
Correct, I forgot there are 2 types, 1 filament between contacts an 2 between contacts and shell. 62417 is the one you need.
Snyder's A-13464 (2 ea.) can be connected between each tail lamp and ground so the thermal flasher works. Electronic flashers are susceptible to ignition noise, causing erratic operation.
