Old 05-20-2026, 09:08 PM   #1
FFOG
FFOG's Avatar
Default Battery Disconnect / Isolator
I currently have the six volt positive ground system in my car. My question is, which terminal do I put my battery isolator / disconnect on, positive or negative?
Thanks in advance!
FFOG is offline   Reply With Quote
Old 05-20-2026, 09:28 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Battery Disconnect / Isolator
Thanks in advance!
make sure you have proper cable size for 6 volts (00 size battery cable,12 volt use #1 size battery cable
www.whidbeymodelaclub.com
Old 05-20-2026, 10:34 PM   #3
old ugly
old ugly's Avatar
put the disconnect or night switch on the ground cable. positive.
with the switch off that will kill all power from the battery.
the same idea as disconnecting your ground wire first before working on your car.
old ugly
my mom would have told me. "these things are here to test us"
old ugly is offline   Reply With Quote
Old 05-20-2026, 10:37 PM   #4
Y-Blockhead
Y-Blockhead's Avatar
Agree!
Old 05-21-2026, 06:21 AM   #5
FFOG
FFOG's Avatar
"Old Ugly" What a great name!
Old 05-21-2026, 07:32 AM   #6
nkaminar
nkaminar's Avatar
The disconnect switch is good for assuring the battery does not discharge while the car sits, or for theft deterrence. But it is most useful when there is an emergency, such as a short causing a fire or the starter switch sticking. So put it somewhere where it is accessible.
nkaminar is online now   Reply With Quote
Old 05-21-2026, 08:23 AM   #7
old ugly
old ugly's Avatar
this is so true.
one of the biggest causes for the battery discharging while the car is parked is the generator cut out. a night switch, as long as you shut the switch off, will prevent that.
old ugly
Old 05-21-2026, 08:28 AM   #8
old ugly
old ugly's Avatar
haha.
my father-in-law gave me that nickname in the mid 1980s, i don't know why, i wasn't even old then.
old ugly
Old 05-21-2026, 08:45 AM   #9
Big hammer
55 years ago , when I first got my A I took her to the car wash to clean the engine preparing for detailing the engine and firewall . Smoke began leaving the firewall wiring, so I flipped the rubber mat back , popped the battery cover off , and wiggled the positive ground battery terminal off ! Well it took me longer to type this than to actually disconnect the battery ! From then on when I reinstall the battery terminal I install it “ a little lose “ so that I can remove it by hand , wiggle and pulling it up and off , Fords original battery disconnect !
get a bigger hammer tap done
Old 05-21-2026, 09:41 AM   #10
gdmn852
gdmn852's Avatar
Hello, I have a disconnect switch on the 31 , connecting to the ground cable, the switch itself is mounted to to seat riser for easy access.Pictures don’t show very well, on other cars without the seat riser , it might be able to mount it on the cross rail under the seat .
gdmn852 is offline   Reply With Quote
Old 05-21-2026, 09:49 AM   #11
Tom F OHIO
Tom F OHIO's Avatar
Like looking for Waldo, I can't see the switch. Good idea though. Can you buy a wire long enough to reach the battery.
Tom F OHIO is offline   Reply With Quote
Old 05-21-2026, 10:00 AM   #12
Y-Blockhead
I have my disconnect switch mount in the floor just in front of the seat in my Town Sedan on the ground wire.
From Bottom:
Old 05-21-2026, 10:11 AM   #13
Tom F OHIO
Tom F OHIO's Avatar
Y-Blockhead did you just mount it in a hole in the frame or did you have to drill one.
Do yu have a picture of it mounted.
Old 05-21-2026, 10:22 AM   #14
Y-Blockhead
Tom, I had to punch a hole in the cross brace in front of the seat. I will try to get a better picture later today.
Old 05-21-2026, 10:31 AM   #15
Trapdoor2
Trapdoor2's Avatar
LOL. I just walked behind my '31 and the brake lights were on. I had removed the rear brakes yesterday, finally disconnecting the last brake rods (fronts were already off). Took me just a second or two to lift the driver's side hood and pull the fuse. It is a blade type, easy in and out.
I normally pull the fuse before any major work. Forgot this time. The brake lights are LEDs, so no big deal. I'll put the batt on charge while I get the drums ready to ship.
'31 Ford Deluxe Coupe "The Green Hornet"
Trapdoor2 is offline   Reply With Quote
Old 05-21-2026, 10:45 AM   #16
Y-Blockhead
Tom, here is a different angle. That is the brake crossshaft just below it.
Old 05-21-2026, 12:31 PM   #17
gdmn852
gdmn852's Avatar
Hello again, better picture this
time two holes were drill for cables in curtain pan to attach to switch, probably won’t be able to duplicate this setup but the is for a 31 Roadster .
Old 05-21-2026, 01:13 PM   #18
Y-Blockhead
Tom, I don't know if this helps are not, hard place to get a picture...
Old 05-21-2026, 05:40 PM   #19
Gary WA
Gary WA's Avatar
Thanks in advance!
Did you ever get the correct answer to your question???!!!
Old 05-21-2026, 05:45 PM   #20
Y-Blockhead
I believe the OP's question was answered in post #3.
