Anyone familiar with this tool? Any recommendations?
Thanks |
I haven’t used this exact one. It appears to be a mid-range induction heater. Cheap ones cost $150-200, pro tools like the Mini-Ductor cost about $800. The main difference is the power level and life cycle. More money means faster heat application and the expectation that you’ll be using the tool daily. For occasional hobbyist use, the low or mid range products are usually fine.
I have a Bolt Buster and like it a lot. So far, it’s handled everything I’ve thrown at it. I prefer it over oxy-acetylene - targets the heat well and avoids open flame.
As far as recommendations, be patient if removing head, manifold or water pump studs. I heat and cool the stud and melt a little candle wax into the threads after heating. If the stud wants to bend, I weld an oversize nut close to the block and use an induction heater attachment that fits around the nut to continue the heat/cool cycle and to let me use a wrench versus stud remover. Patience works for me.😎☘️ |
I agree with this, and I would also say the heater should be your second line of attack after trying a stud remover on a SHORT socket wrench. Using the short wrench lets you see if the stud will come out unassisted, without letting you put so much force on it that it breaks.
Excellent point Alex.
I use 1/4" drive to install valve covers & oil pans for the same reasons. |
The heat is what does it trick. It expands the stud which puts a strain on the stud. When it cools it is a slightly smaller diameter. Any kind of penetrating oil also helps.
They work great and easier than digging out a torch.
I bought a cheap one from TEMU last year, used it to remove the studs from my flathead V8, the only issue is that sometimes it overheats and shuts off. I just let it cool for about an hour and then continue on with my work. I stopped buying from TEMU as they have raised prices and added $3.99 shipping to almost every item. I can find stuff on eBay or Amazon for the same price.
| Thread Tools | |
| Display Modes | |
