Old 05-11-2026, 07:56 PM   #1
Ken Arms
Ken Arms's Avatar
Default gas cap leak
could use some suggestions as to stop my gas cap from spilling when full. I have tried a new gasket on original cap, tried a new cap as well. Car has a new drake tank with a spring loaded flipper. (34 ford). Ken
Ken Arms is offline   Reply With Quote
Old 05-12-2026, 09:32 AM   #2
TJ
TJ's Avatar
Default Re: gas cap leak
A regular cap or a locking cap?
Old 05-12-2026, 09:35 AM   #3
19Fordy
19Fordy's Avatar
Can you post photos of the cap you are using?
Also, try a double gasket.
Old 05-12-2026, 09:47 AM   #4
Kube
Super Moderator
Kube's Avatar
My guess? Overfilling the tank.
The design of the filler tube is not the greatest and often enough, when the tank is very full, the fuel will get past the gasket.
How about next time you put gasoline in the tank, stop at half or so and see if that cures the issue.
Old 05-12-2026, 11:29 AM   #5
34fordy
34fordy's Avatar
I thought my improvement was perfect until I looked today. Back to the drawing board. lol
34fordy is offline   Reply With Quote
Old 05-12-2026, 09:04 PM   #6
325w
I use red rubber from the Ace hardware. Cut to fit. They last for a year are so.
325w is offline   Reply With Quote
Old 05-12-2026, 11:11 PM   #7
Karl Wescott
Karl Wescott's Avatar
1933-34 originally used a NON-vented cap which sealed the fill neck opening. Locking gas caps by their nature are vented and will spill fuel. Confusion abounds about the replacement caps in part due to Ford in the "Green Bible" back interchanging the later vented cap to 1932.
The Drake tank should be vented on the top (usually in the pickup tube area). With a non vented cap and a non vented tank and a strong fuel pump you can make a 12 gallon tank into a 2 gallon tank (Our family did it on a '68 Plymouth wagon).
My guess is the wrong cap.
Karl Wescott is offline   Reply With Quote
Old 05-13-2026, 04:19 AM   #8
vincent
I had a (non - working) lockable cap on my 34, spilling fuel when doing fast right turns with a full tank. I replaced the lock with a container attached to the cap that allows to breath enough but would need several clockwise laps with a full tank before the little container is filled with fuel and will spit through the breathing hole. If anyone is interested I can take a pic.
vincent is offline   Reply With Quote
Old 05-13-2026, 11:22 AM   #9
TJ
TJ's Avatar
I've had good luck using the caps from Napa Auto Parts. They are stainless with a rubber gasket. The only drawback is they have a flat spot on the top and you have to remove the decal on the flat spot. Never had one leak.
Old 05-13-2026, 12:50 PM   #10
Ken Arms
Ken Arms's Avatar
thanks everyone, I just ordered a new cap from bob drake, its advertised as a vented cap with neoprene gasket and no leaks. I will provide feed back if it works. Ken
Old 05-13-2026, 01:42 PM   #11
The Art Doctor
The Art Doctor's Avatar
Mine does the same. My tank is new Drake too and needs a vented cap due to a modern sending unit. Been trying to figure out where its coming from and I think it is between the seal and the top flat part of the neck as its slightly wet there when I take the cap off. There is always a small puddle between the slosh valve and the opening so I know the slosh valve is not terribly effective but probably it would be worse if it were not there. The cap is very tight on and off so I can imagine adding more gasket thickness would not help, possibly a fresh one as you are doing would be the trick. I'll wait and see how yours turns out.
The Art Doctor is offline   Reply With Quote
Old 05-13-2026, 02:25 PM   #12
34fordy
34fordy's Avatar
I didn't have any luck but maybe this is "New and Improved" so be sure to let us know Ken!
Old 05-13-2026, 03:12 PM   #13
petehoovie
petehoovie's Avatar
Old 05-14-2026, 04:48 AM   #14
1934
1934's Avatar
I had the problem of leaking gas whenever I filled up. I tried everything, different caps, gaskets, etc. Finally solved the problem with a cap from Tanks Inc. No more leaks!
Doug.
1934 is offline   Reply With Quote
Old 05-14-2026, 03:21 PM   #15
JimG
JimG's Avatar
I also got a cap from Tanks for my 34 a few years ago. Doesn't leak no matter how full I fill it.
JimG is offline   Reply With Quote
Old 05-14-2026, 04:07 PM   #16
34fordy
34fordy's Avatar
Could you provide the part number please. When I went on their website I didn't see the appropriate part. Possibly you could post a picture?
Old 05-14-2026, 06:07 PM   #17
petehoovie
petehoovie's Avatar
See > https://www.tanksinc.com/index.cfm/p...prod/prd91.htm
Only $15.95
Part # TC-32PV
Description:
1932-48 Ford Chrome Fuel Cap for 2-19/32" Neck- Vented
TC-32 Back Side of Cap - Non Vented
TC-32PV Back side of cap. Pressure vented.
TC Back side of cap. Vacuum relief.
Old 05-14-2026, 07:51 PM   #18
34fordy
34fordy's Avatar
Thanx Pete. Don't know why I could not find it. Kinda what I figured that it would need a little reed valve or something similar. Really a reasonable price!
Old 05-18-2026, 06:27 PM   #19
34fordy
34fordy's Avatar
[QUOTE=petehoovie;2451565]See > https://www.tanksinc.com/index.cfm/p...prod/prd91.htm
Only $15.95
Part # TC-32PV
I ordered and received this nice cap today. I put my mouth on the blue (check-valve) and found that I had to lightly suck to open the vent. I am wondering if this negative pressure affects the fuel pump discharge pressure or the pumps ability to bring fuel to the pump. I would think that the pump pressure would not be affected.
Old 05-28-2026, 10:08 AM   #20
The Art Doctor
I think that it would be great. I just ordered two, thanks for sharing.
