My 40 four door steering is sloppy. Driving down the road I need to work the wheel more than I would like. I had a mechanic try to make an adjustment on the top of the steering box but he was unable to get a full notch. Balance of steering gear is in good condition so I feel the problem is in the box. What are my options? Is there a rebuild service for this? How big of a deal is removing the gearbox and long shaft? Thanks in advance.
my only information is via the internet and a local hot rod expert from the 60's that said the boxes can be adjusted but only so far. and if too far the steering will get too tight, and at which point it needs to be replaced with a used one in better condition.
now i suppose that there are aftermarket rack and pinion setups or equivalents that would fix things but would involve some modifications and more work. IME, i'm still trying to decide if i'm a victim of steering box/tierod/steering arm/king pin/ball joint wear or if the manual steering on a '41 with its enormous steering wheel just involves a lot more movement than that to which i am accustomed. ...i'm sure i've got suspension issues too!
We put a rebuilt unit from Lares Corp. in a '40 after determining the original box was beyond adjusting.
Not too bad of a job; just be sure to get the front up high enough. |
Suggest you look through and adjust with the attached instructions. There is more to it than your mechanic may be familiar with.
Archives of historical but relevant older articles: ------------- Hover mouse over the links below and click! ~~~~~~~~~~~~~~~~~--------------- Rumble Seat’s Notes Techno Source for the 1932 thru 1953 Flathead Ford |
I agree with Glennpm. Follow the instructions he has provided.
also the worm shaft bearings cannot have play |
Haaanngg on sloopy, sloopy hang on!
| Thread Tools | |
| Display Modes | |
