Old 05-06-2026, 06:34 PM   #1
Tom in TN
Tom in TN's Avatar
Default Water pumps squealing
Hey y’all,
My 34 is running a 1936 flathead with the water pumps in the heads.
Both pumps have zerk fittings for grease AND both pumps have been ‘enhanced’ by Skip. Due to some health issues (cancer) the motor hasn’t been run for maybe 3 years.
I cranked her up the other day and after a short time, the pumps started squealing like stuck pigs. So, I injected some grease and they quieted down.
That was about 3 weeks ago.
Started her up today and the squealing is back.
My questions: Can sealed bearings be installed into these pumps?
Squirting grease into the bearings that are inside there just doesn’t seem to be working like I think it should.
Does Skip (or anyone else) install sealed bearings as a modification for these pumps?
Any other ideas /suggestions?
Thanks
Tom in TN is offline   Reply With Quote
Old 05-06-2026, 08:24 PM   #2
ford38v8
ford38v8's Avatar
Default Re: Water pumps squealing
If you’re using plain water as a coolant, add some water pump lubricant.
Alan
Old 05-06-2026, 08:34 PM   #3
mcgarrett
Is the belt old and dry? Try spraying some belt dressing on the belt and see if that helps. Most auto parts stores sell it.
Old 05-06-2026, 10:28 PM   #4
Tom in TN
Tom in TN's Avatar
Thanks, but I'm running a 50/50 mix of anti-freeze and water..
Old 05-06-2026, 11:14 PM   #5
hueyhoolihan
my first thought when hearing a squeal from the engine compartment is always "belt" too.
hueyhoolihan is offline   Reply With Quote
Old 05-07-2026, 12:21 PM   #6
glennpm
glennpm's Avatar
https://skipscoilsandpumps.com/
941-505-9085
941-639-0920
[email protected]
George Haney
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 05-08-2026, 02:26 PM   #7
kevinshea
kevinshea's Avatar
The Squeal certainly would suggest first looking at the bearing, the belt, etc.. all the external things. Have you used a stethoscope/stick to try to isolate the noise?
Then, given that the coolant has sat for 3 years, you may well have some gel in the coolant passages ( I did!).. look into how antifreeze that sits turns into gel.. My suggestion is to use Thermocure to flush out the system and assure yourself of a nice clean system, and avoid any overheating when you are on the road again. I ordered Thermocure at my local Oreillys. Also, folks in the Fordbard suggest No-Rosion.
The coolant and the gel often do find the low points, but your 35 has elevated water pumps. The pumps should be a pretty straightforward job to remove and check the status.
kevinshea is offline   Reply With Quote
Old 05-11-2026, 06:19 AM   #8
Terry,OH
Terry,OH's Avatar
Give Skip a call early in the morning.
