Old 05-06-2026, 11:32 AM   #3
miker98038
miker98038's Avatar
Default Re: Overdrive Expert Needed
40’s correct. Might be 35 or so, but should still go in. If the drill doesn’t work try running a jumper sw, out thru the hood and into the window if necessary. That should drop the relay in. If it work, and the drill motor checks out on the gov then it’ll be the wire or the connections.
K is occasionally active at yblocksforever.
miker98038 is offline   Reply With Quote
