what modifications can be done to make the clutch pedal push down easier . And has anyone ever tried to replace clutch linkage with hydraulics to make it push down the pedal easier . I do not think hydraulics will fit but maybe someone out there has tried it .
There is a longer clutch arm you can buy from the vendors.Makes quite a difference too.Not real expensive.
I have the Ford V8 clutch in my car and it is easier. Might not be easy enough depending on your physical condition.
I am 81 years old. I have arthritis in both my knees. I few years ago I could barely walk. I got some shots in my knees that made an instantaneous difference. An orthopedic surgeon can treat you. The problem with the shots is that they eventually don't work which leads to surgery. I started taking Move Free, 3 tablets a day, and now I have full use of my knees and can hike with my wife. Move Free will build back the cartilage. Exercise also helps. Walking, swimming, and bike riding are good. I believe that you can live a health long life if you keep active and exercise regularly. Also the Move Free.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 05-04-2026 at 08:30 PM. |
I have heard of modern diaphragm pressure plate being used. I have the longer clutch arm that Keith mentioned. Works for me... so far.
https://www.musclecarsandclassics.ca...t5eZfP_FI0zHZD
https://www.mikes-afordable.com/product/A7510WA.htm
#7 | |
Snyders to the rescue... LIGHTENED FLYWHEEL WITH V8 CLUTCH Part # A-6375-V8 | Model Year 28-31 A little pricey at $645 plus shipping. Probably $750 delivered. They say they need a "core" exchange. Not sure if they're looking for a Model A core or a V8 Core. Think more shipping... Joe K
Shudda kept the horse. Last edited by Joe K; 05-05-2026 at 07:37 AM. |
With the stock Model A producing around 127' lbs of torque You would think the stock pressure plate was way overkill. You would think maybe having a capacity of 200’ lbs of torque holding ability would be more than enough and provide a very soft clutch pedal.
Modern diaphragm pressure plates typically have a much softer clutch pedal load by design. I would think you could actually remove every other spring on the factory pressure plate and still have adequate holding ability with a stock engine of course, and in addition to using the longer arm on the clutch release shaft. In reality the clutch only needs to hold 127 foot pounds of torque and 40 hp so with a stock Model A engine if you double that in capacity for the clutch pressure plate it really doesn’t need to have that much spring pressure at all. The current pressure plates are way over capacity to cover higher powered applications in my opinion.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask Last edited by Fullraceflathead; 05-05-2026 at 08:28 AM. |
I had my lightened V-8 clutch flywheel redrilled for a 1986 Thunderbird Turbo Coupe diaphragm pressure plate. It still uses the stock Model A clutch disc and throw-out bearing. I can easily use three fingers to depress the pedal. Clutch engagement is very smooth and progressive.
That's a perfect example of how nice a diaphragm pressure plate actually operates and functions with only moderate pressure.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
I am 83 & my Victoria has a V8 clutch that is easier to work than the stock clutch. Also, there are 2 options for longer clutch arms.
Bob Bidonde |
#13 |
Ditto
| Thread Tools | |
| Display Modes | |
