Old 05-01-2026, 02:42 PM   #1
corvette8n
corvette8n's Avatar
Default emulating king-seely fuel sender freq.
Could a raspberry Pi zero be used to emulate a K-S fuel sender. My ‘41 has an Argentine made after market sender, I was wondering if a micro computer could be made to work? Any one ever put an oscilloscope on a King-Seely fuel sender.?
Old 05-01-2026, 05:38 PM   #2
19Fordy
19Fordy's Avatar
Default Re: emulating king-seely fuel sender freq.
Good question? Can you give it a try and see?
Old 05-01-2026, 06:25 PM   #3
tubman
tubman's Avatar
I'll ask my buddy about this. He's a electronic expert, and the guy who designed my 6-12 volt, positive ground to negative ground tachometer driver. From what I know, the programming to simulate the K-H should not be that bad, but providing the input to the computer from the float would probably be the hard part.
Thinking about this some more, running a resistance sender and converting the output to KS format might be easier I'm sure it can be done with some sort of chip, but my experiences with the tach driver shows such projects are economically unfeasible.
Old 05-01-2026, 06:43 PM   #4
rich b
rich b's Avatar
I always wondered about putting S/W (or other) modern dash gauge guts inside the Ford gauge to match up with the available resistance tank senders.
Old 05-02-2026, 07:38 AM   #5
Don W/Norfolk
I have found a device purported to be able to solve the KS sender to gauge problem.
https://www.technoversions.com/MeterMatch.html#kit
Your mileage may vary.
I love this country; it's the damn idiots running the government I'm afraid of.
Don W/Norfolk is offline   Reply With Quote
Old 05-02-2026, 08:12 AM   #6
cadillac512
cadillac512's Avatar
That looks very promising! Although it doesn't operate in the same manner as the KS senders, it has enough set points in the programming that it should be able to provide a linear signal to the gauge and be accurate. Thanks for the link!
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'30 Model A Speedster
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 05-02-2026, 09:59 AM   #7
rotorwrench
rotorwrench's Avatar
KS was ingenious in how they designed their system to translate the float buoyancy to apply mechanical pressure through a sealed diaphragm to a bimetallic strip with a contact points set to affect a current controlling pulse rate output. The speed of opening and closing the circuit was directly affected by only a small amount of mechanical pressure against the very small bimetallic strip. It all fits inside a small sealed cavity in the sender head. It includes the little resistace spool of wire and the small carbon resistor for calibrating the system to the bimetallic indicator gauge. The sender head cover can be pryed up and off to reveal the internal components of it. The points can be cleaned if a person is very careful. They don't wear out like a rheostat sender and nothing electrical is exposed to the inside of the fuel tank. Thay last longer than all the other systems I've ever worked on and that includes the capacitance based systems. The only system that is more simple is a directly viewed float type system like a model A has but those aren't practical if the tank is remotely mounted. The fuel tank has to be very close to the operator of the vehicle.
